Full Version: cant log into youtube in xbmc
Hi all just trying to get the youtube plugin working and I cant get it to login with my username and password. Is there a trick I need to know?
I even changed my gmail password thinking it was wrong but no I have correct password and username and it just wont work....
Any suggestions much appreciated
cheers rileyp
A log would be nice. Because we don't know what OS you use or what version of XBMC or what version of youtube.
But just try; instead of username your whole gmail address.
Yeh me too since 3 day i'm enable to conect whith my account youtube ,i tray it bothe edden first and Dharma downloded and instaled by xbmc abd it said login failed and somme times change url somthing
and hers the log
hop you fix it soun and thx a lot
http://pastebin.ca/2160803
(2012-06-10, 20:34)HenrikDK Wrote: [ -> ]Hi, login code is broken atm, we're preparing a fix..
yep, the Youtube Plugin is broken ATM, and as you can se, the guys are working on a fix Smile
Nevermind....
10char... mods delete.. w/ever
Here is the solution!
http://youtu.be/kIPtuL0ia48
