i recently updated to eden and my movie scrapers have stopped updating. If I set content it allows me to choose IMDB but doesnt seem to do anything. If I go back it says none for the content. I'm also missing the movie info from right clicking the film. I do get the capture of the movie frame but nothing more than that.. Any suggestions..
I thing I'm having a similar problem. i load the move a IMDB loads but nothing saves i the file. Sorry I'm new to all this. heres my log.
/show.php?id=4551&hash=41546843
If there is something i can change or do to make XBMC work better please tell me
Thanks in advance
You may have a similar problem to me whereby it scans but nothing shows up. My fix (and not sure why this works) is to remove an item from the library first then rescan. So once I have added a movie to my folder I navigate to movies in XBMC on the first movie I go to the context menu, remove it from library, then go back to context menu and update library, pulls in the one I just removed plus any extras.
See if that helps!!
But isn’t it supposed to save that information like the fan art, trailer, actors flie ext. to the file that the particular movie is in?
give this link a try
http://xbmclogs.com/show.php?id=4569
No it isn't, only if you do an export.
Having the movie scraped it will store those in its database and thumbnail cache only.
...and this log doesn't show any scraping.
the video scanner didn't seem to find any new movie.
