Full Version: Same setup on another XBMC setup.
Hi All
Apologies in advance if this has been asked and answered already (I can't seem to find a solution), but does anyone know which folders and files I would need to copy on my Master Setup so I can then Paste them on my Secondary Setup so they both have the same settings?
They both have the same skin so a conflict would hopefully not arise there.
Any help would be appreciated.
Wiggo
Everything in the userdata library would be a start. You didn't say what O/S or skin you had... in Win/7 the entire roaming folder would do it.
Hi
Im using Aeon MQ 4 and the o/s is W7.
Will the userdata and roaming folder's be adequate for the o/s and skin I am using?
Cheers
Wiggo
get the xbmc folder that the userdata (wiki) folder sits in. That way you have settings and all the skin/add-on files, etc. For the most part, this works surprisingly well between settings (even of different operating systems).
Thanks for the input guys. Worked perfectly.
Wiggo
