hi I've just installed xbmc for the first time on iPad 2. i was playing with the settings in video calibration and now my screen is out of line and i can't seem to get it back in line. is there a way to set back to default settings?
regards
iOS_FAQ#SkinChange (wiki)
You can use SSH and the rm command, or use
Cyberduck (wiki), to delete the guisettings.xml file. That will reset those settings.
hi i have ssh into the iPad but can't find the guy settings u refer to. could u point me in the right direction pls.
i have found it thanks. i found the command and did a search thanks for ur help
Oh, and you can also use something like iFile from Cydia (if this happens again). I keep forgetting that the iDevices have GUI file managers, while the ATV2 doesn't.
