Full Version: Frodo Image Caching issue (I think)
Hi All,
Really loving the May cycle of Frodo. However my movie thumbnails don't seem to have refreshed (they're now blank), apart from 10 films (I think these ones are the ones used my the recently added script (not sure though).
I've tried leaving my mac on for a few hours after it finished the TV shows (no problems), but no progress had been made (approx 500 films).
I refreshed a movie manually and that did the trick for that film - is there something I can do to force XBMC to make new cache of the images?
Thought I would post this thread in case there was something I could do to help (by testing) or something I missed Smile
Any help would be humbly appreciated.
Thanks for XBMC,
Chris!
OSX Version: 10.7.4 (Lion)
Platform: MacBook Pro 15" mid 2010
Install Method: DMG
SVN Revision: Alpha2 Git:20120531-1495cbe (Compiled June 2 2012)
FULL Debug Log: http://pastebin.com/5z1keWEM
(Hovering over a film, 40 Year old Virgin, that doesn't have a picture then refreshing it to get one)
Skin name: Default Skin (confluence)
Thanks for the friendly and prompt pointer Martijn Smile
I've downloaded your Library info update script and configured it to be on. I'm a little confused though, does it work silently in the background?
Thanks,
Chris!
(2012-06-09, 21:41)Chris! Wrote: [ -> ]Thanks for the friendly and prompt pointer Martijn Smile
Thanks,
Chris!
It isn't ready yet for the images. It only updates ratings/votes/certifications.
Perhaps tomorrow evening it is ready.
You need to run it manualy from the program section.
:HeadSlap: - Need to practice reading posts better. Sorry.
I look forward to it, many thanks for all you help and hard work Smile
Pleasant regards,
Chris!
