Full Version: Web and remote servers fail to start after returning from emulator in solo mode
I decided to post in here about my RCB problems, I have posted in the RCB thread, but I figure maybe it should be here as well
In a nutshell I made .xbmc/addons/script.games.rom.collection.browser/applaunch.sh executable with chmod +x, which enabled solo mode to work. Xbmx exits fine, but after pressing esc to leave pcsxr, xbmc opens with an error of webserver failed to start and remote server fails to start.
This is my last post in the other thread, which should explain just what I'm going through.
Quote:Looks like I'll have the privilege of fixing the webserver fails to start and remote server fails to initiate problems. It has followed me to Ubuntu 10.10. It's clear this is an Eden problem, since I was on the previous version without any of these errors.
The Rom Collection Browser service addon is supposedly installed and active.
This is my terminal readouts, perhaps it will be of use
xbmc@xbmc:~$ xbmc
params.c:OpenConfFile() - Unable to open configuration file "/home/xbmc/.smb/smb.conf":
    No such file or directory
params.c:OpenConfFile() - Unable to open configuration file "/home/xbmc/.smb/smb.conf.append":
there is no soundcard
Shutdown nice
Shutdown hard
/usr/games/pcsx -nogui -cdfile /media/sdb1/Games/PCSX/Roms/Legend of Dragoon/Legend of Dragoon_Disk1.iso
Killed
xbmc@xbmc:~$ NVIDIA Corporation
GeForce 210/PCI/SSE2
Could not open BIOS:"/media/Media/Games/PCSX/Bios/SCPH1001.BIN". Enabling HLE Bios!
Ignore any sound related errors
And the Bios error
EDIT:
Wow downgrading to Dharma looks to be a lot trickier than I thought, does anyone have a dharma deb package for ubuntu?
EDIT
Heres a snippet of my xbmc.log file
No idea if it may help
18:06:09 T:3019528000    INFO: initializing python engine.
18:06:09 T:3019528000   DEBUG: new python thread created. id=4
18:06:09 T:3019528000   DEBUG: waiting for python thread 1 to stop
18:06:09 T:3019528000   DEBUG: python thread 1 destructed
18:06:09 T:3019528000   DEBUG: waiting for python thread 2 to stop
18:06:09 T:3019528000   DEBUG: python thread 2 destructed
18:06:09 T:3019528000   DEBUG: NetworkMessage - Starting network services
18:06:09 T:3019528000  NOTICE: Webserver: Starting...
18:06:09 T:3019528000   ERROR: WebServer: Failed to start the webserver
18:06:09 T:3019528000  NOTICE: starting upnp server
18:06:09 T:2846878576   DEBUG: Thread XBPyThread start, auto delete: 0
18:06:09 T:2846878576   DEBUG: Python thread: start processing
18:06:09 T:3019528000  NOTICE: starting upnp renderer
18:06:09 T:2846878576  NOTICE: -->Python Interpreter Initialized<--
18:06:09 T:2865093488  NOTICE:  StorageServer Module loaded RUN
18:06:09 T:2865093488  NOTICE: StorageClient-0.9.2 Starting server
18:06:09 T:2865093488  NOTICE: StorageServer-0.9.2 Storage Server starting /home/xbmc/.xbmc/userdata/Database/commoncache.db
18:06:09 T:2846878576  NOTICE: Previous line repeats 1 times.
18:06:09 T:2846878576   DEBUG: Process - The source file to load is /home/xbmc/.xbmc/userdata/autoexec.py
18:06:09 T:3019528000  NOTICE: ES: Starting event server
18:06:09 T:3019528000   ERROR: JSONRPC Server: Failed to connect to sdpd
18:06:09 T:2846878576   DEBUG: Process - Setting the Python path to /home/xbmc/.xbmc/userdata:/usr/share/xbmc/addons/script.module.simplejson/lib:/usr/share/xbmc/addons/script.module.pil/lib:/home/xbmc/.xbmc/addons/script.common.plugin.cache/lib:/home/xbmc/.xbmc/addons/script.module.simple.downloader/lib:/home/xbmc/.xbmc/addons/script.module.parsedom/lib:/home/xbmc/.xbmc/addons/script.module.elementtree/lib:/usr/share/xbmc/addons/script.module.pysqlite/lib:/usr/lib/python2.6:/usr/lib/python2.6/plat-linux2:/usr/lib/python2.6/lib-tk:/usr/lib/python2.6/lib-old:/usr/lib/python2.6/lib-dynload:/usr/local/lib/python2.6/dist-packages:/usr/lib/python2.6/dist-packages:/usr/lib/python2.6/dist-packages/PIL:/usr/lib/python2.6/dist-packages/gst-0.10:/usr/lib/pymodules/python2.6:/usr/lib/python2.6/dist-packages/gtk-2.0:/usr/lib/pymodules/python2.6/gtk-2.0:
18:06:09 T:2846878576   DEBUG: Process - Entering source directory /home/xbmc/.xbmc/userdata
18:06:09 T:2846878576    INFO: Scriptresult: Success
18:06:09 T:2813307760   DEBUG: Thread CEventServer start, auto delete: 0
18:06:09 T:2813307760  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
18:06:09 T:2813307760  NOTICE: UDP: Listening on port 9777
18:06:09 T:3019528000   ERROR: JSONRPC Server: Failed to bind serversocket
18:06:09 T:3019528000  NOTICE: starting zeroconf publishing
18:06:09 T:2846878576    INFO: Python script stopped
18:06:09 T:2846878576   DEBUG: Thread XBPyThread 2846878576 terminating
18:06:09 T:2813307760   DEBUG: CZeroconfAvahi::clientCallback: client is up and running
18:06:09 T:3019528000   DEBUG: CLastfmScrobbler: Clearing session.
18:06:09 T:3019528000   DEBUG: CLibrefmScrobbler: Clearing session.
18:06:09 T:3019528000   DEBUG: new python thread created. id=5
18:06:09 T:2796522352   DEBUG: Thread Jobworker start, auto delete: 1
18:06:09 T:2788129648   DEBUG: Thread XBPyThread start, auto delete: 0
18:06:09 T:2788129648   DEBUG: Python thread: start processing
18:06:09 T:3019528000   DEBUG: ------ Window Init () ------
18:06:09 T:3019528000   DEBUG: ------ Window Init (Pointer.xml) ------
18:06:09 T:2873486192  NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:00
I should also mention that exiting from within xbmc using the exit xbmc option, webserver and remote servers activate normally.
Can anyone help me figure out what changed from dharma to eden to have what I can only assume the web and remote server not be successfully killed by RCB? This has happened in xbmcbuntu and ubuntu 10.10, so It's not on the ubuntu side. I had this exact setup working fine in Dharma so something must have changed.
Please help, I feel like I'm in limbo with my htpc Sad
Thanks in advanced,
-David
