Full Version: moviemeter.nl scraper small bug Science-fiction and Sciencefiction
This looks really weird because on Moviemeter it is shown correct.
I can update every field that contains the wrong value easily. But then you get the issue again with newer movies that has the same issue.
Maybe it was a bug at MovieMeter and they fixed it. So it will never happen again.
I will at least change one of them to the same as the other.
But which one should be used? They use Sciencefiction on the MovieMeter website so i will also pick that one.
