Full Version: windows 7- turn screen off
I am using a gateway all in one touchscreen pc. When I have xbmc on my screen does not turn off. If I exit xbmc then it will turn off on the specific time that I set in the options. Is there a way for xbmc to be able to allow this? I dont want it to go to sleep since this pc is my plex server and if I want to access it the pc has to be on.
Any ideas?
I only see 3 options
sleep timer
shutdown function timer
shutdown function
Screensaver dim to 100% black? Assuming the light was bothering you.
Does this also happen when XBMC is minimized?
(2012-06-11, 04:14)MassIV Wrote: [ -> ]Screensaver dim to 100% black? Assuming the light was bothering you.
Yes this happens when minimized also.
