Yes, unfortunately playback through the addon is broken right now due to an Rdio API change over the weekend. I'll hopefully get it working again in the next week or so, but unfortunately it's a bit of a tricky change. Will post here when I have some news. Sorry for the inconvenience.
Hi all, I think I've found a fix for the Rdio playback problem. I've released a new version 1.3.1, please let me know if this fixes the problem for you.
Perfection! Thank You !!!
No luck here with ATV2
http://pastebin.com/WTAF8QJL is my log
Can see my playlist,then pick one and the song but when I click on it, I get playback failed error
Hope you can fix
Hi @
dallasnights, sorry to hear you're still having problems. Looks like you're still getting the same error so obviously my fix hasn't worked for everyone.
First off, can you double check that you are in fact running version 1.3.1 of the Rdio plugin? Assuming so, can you find open the following file in an editor:
<xbmc_home>/addons/plugin.audio.rdio/rdioxbmc.py
Then find the line that looks like this:
'playerName': 'api_429413',
and change it to this:
'playerName': 'api_18683',
Then try playback again. If it still doesn't work, try changing a few of the numbers in the "api_xxxx" string randomly and trying again.
Let me know how it goes.
ok couple of things
1) It shows 1.30 but keeps saying its updating and still it shows 1.30
Did what you said no luck even with random numbers
http://pastebin.com/i8W8CnSp
Hope you can fix for ATV2 back to where it works again
On my end, I can confirm version 1.3.1 works like a charm on aTV 2 with Eden.
By the way - thanks a millions amped for this add-on ... it's a godsend for my setup!
Thanks for the tip think I have fixed all permission errors,
I used in Putty
chown -R mobile:mobile /private/var/mobile/Library/Preferences/XBMC/
Anyhow now on 1.31 for sure but still wont work see the log here
http://pastebin.com/yrzfqq4B
OK, it's failing for me again now also. Frustrating. Sorry folks, will keep looking into it.
(2012-07-07, 01:30)ampedandwired Wrote: [ -> ]Hi @dallasnights, sorry to hear you're still having problems. Looks like you're still getting the same error so obviously my fix hasn't worked for everyone.
The api_18683 only has 5 digits compared to the 6 of the original api_429413.
Is the new one correct?
Hi Paulpoco, actually as it turns out I don't think fiddling with this number is going to help. "api_429413" should work OK. The problem with playback is something else.
Hi all, I've released v1.3.2 which I'm hoping will fix the playback issues. Rdio seem to have put a bit of extra security on their Flash streaming API which has made playback through XBMC a bit difficult. I'm unsure if this fix will work for everyone, or how long the fix will work for, but please let me know if it works for you.
(2012-07-08, 06:16)ampedandwired Wrote: [ -> ]Hi all, I've released v1.3.2 which I'm hoping will fix the playback issues. Rdio seem to have put a bit of extra security on their Flash streaming API which has made playback through XBMC a bit difficult. I'm unsure if this fix will work for everyone, or how long the fix will work for, but please let me know if it works for you.
It works for me now, thanks a lot.
