2012-06-11, 08:22
Hey guys,
I am having a couple of strange problems with the nightly installs from GIT at the moment.
The problems are:
1. Browsing the library in anything but file browsing to the share is causing a crash in XBMC (2 nights in a row now, new nightly didnt help)
I have tried clearing my library (as i originally set it up with eden stable) but that didnt help.
2. Problems with HD movies playing fast and not having passthrough audio via pulseaudio (see note at end)
the relevant info is:
XMB Version: As above, XMBC 12.0-ALPHA3 GIT:20120610-3277107 (plus one before it i didnt note down)
OS - Fedora 17, x86_64 (64 bit)
Install method - from source via GIT. - GIT was current at time of writing (2012-06-12 16:10 +10 GMT)
Instructions to reproduce the error:
1. Install XMBC from GIT (clone, bootstrap, configure, make, make install) (my configure option is ./configure --with-lirc-device=/var/run/lirc/lircd --enable-pulse --enable-libusb --enable-libcec --enable-libmp3lame btw)
2. Add something to the libarry (in this case, i have tested with my TV and movies collections, both produce this crash)
3. Attempt to view the library in full (viewing recent items or browsing to the files via the share works fine however)
4. XBMC dies immediately with a crash message.
The XMBC log for this is here:
http://xbmclogs.com/show.php?id=3471
For some reason i have stopped getting core dumps ( I got them the first few times however), once I have followed the info and gotten one sucessfully i will post that too.
Some quick info btw:
I am trying to get a nightly install going to be able to use pulseaudio's passthrough functionality. I have managed to get my audio to work in the past with stable dharma (and then eden) by crippling pulseaudio in the OS and then pointing XBMC direct to the hw address, however this is not clean, plus means i loose OS sounds and menu sounds within XBMC.
The other problem im having relates to HD movies playing way faster than they should + audio not working but i will do some research and post that in a seperate topic if i cant fix it. I managed to test this by browsing through the SMB share to the files and playing from there. SD movies work fine (both audio and video, not passthrough audio)
I hope i have included all the info (minus the pending backtrace), let me know if i have missed anything....
Cheers!
Ayden
The problems are:
Cheers!
Ayden
