Full Version: {solved}Proper viewing resolution
Hi all!
I am using my HTPC with a projector and big screen. The screen is 16:9. I have 2 connections from the HTPC, DVI & HDMI. My issue is that When I am using dvi connection, myscreen is full (16:9) on HD movies. Fills the screen perfectly. When I play the same movie through the HDMI connection, it cuts the size dramtically. Is that a setting within my computer system or XBMC? A guide or link that somebody can point me to?
Thanks all!
