Full Version: Wow Impressed with Codec support but....
Hi
XBMC really is capable of playing nearly every video format / container I threw at it and I am extremely impressed! To do that in Windows Media Center I had to be a codec guru.
However I have some .MOV files that don''t play in XBMC, they are DRM stripped files from the Apple iTunes store. Below is the media info output.
How would one go about getting these files to play in XBMC?
They would also not play in WMC initially until in the Shark Codec pack, I change the Decoder used for the AAC audio from libavcodec to libfaad2 and that solved the problem and they played fine in WMC / WMP.
Also I cannot play .WTV Media Center recorded TV files, I get sound but no picture. The older DVR-MS format plays OK though.
I haven't tested bit streaming the audio to my AVR or anything fancy like that yet.
.MOV Media Info Output:
General
Complete name : \\whs01\Videos\HD-Showcase\Apple DRM Stripped\9 (2009).mov
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt
File size : 932 MiB
Duration : 1h 19mn
Overall bit rate : 1 644 Kbps
Movie name : 9 (2009)
Performer : Shane Acker
Genre : Kids & Family
Recorded date : UTC 2009-12-29 08:00:00
Encoded date : UTC 2011-01-21 11:56:05
Tagged date : UTC 2011-01-21 12:21:37
Writing library : Apple QuickTime
Copyright : © 2009 Focus Features. All Rights Reserved.
Cover : Yes
desc : From visionary filmmakers Tim Burton (The Nightmare Before Christmas) and Timur Bekmambetov (Wanted) and Academy Award-nominated director Shane Acker comes this visually stunning and original epic adventure. In the final days of humanity, a dedicated scie
stik : 9
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=2, N=24
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration : 1h 19mn
Duration_LastFrame : -8ms
Bit rate mode : Variable
Bit rate : 1 511 Kbps
Width : 640 pixels
Height : 460 pixels
Display aspect ratio : 1.855
Original display aspect ratio : 1.391
Frame rate mode : Constant
Frame rate : 23.976 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.214
Stream size : 857 MiB (92%)
Language : English
Color primaries : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Transfer characteristics : BT.709-5, BT.1361
Matrix coefficients : BT.601-6 525, BT.1358 525, BT.1700 NTSC, SMPTE 170M
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Duration : 1h 19mn
Bit rate : 126 Kbps
Channel(s) : 2 channels
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 71.6 MiB (8%)
Language : English
