Didn't know where to post this, but, since I think Ronie is working on this, I'll ask here. I'm using XBMC 11, no nightlies, and I keep getting watchlist failed. Is this script broken on everything or am I not holding my mouth right?
What does it exactly do and we need.a full
Debug Log uploaded on xbmclogs.com or pastebin.com
thanx, will look into it.
looks like there's an invalid 'lastplayed' date stored in the db.
i've seen this one time before, but i'm clueless as to why this can happen.
Should I delete my db and resrape?
(2012-06-13, 02:34)bobrap Wrote: [ -> ]Should I delete my db and resrape?
that might fix things, but you'll loose the 'watched' status of your movies most likely.
(2012-06-13, 20:31)ronie Wrote: [ -> ] (2012-06-13, 02:34)bobrap Wrote: [ -> ]Should I delete my db and resrape?
Set your source to none. it will ask to clean library and then set content again.
This should preserve the watched status but will rescrape all data
(2012-06-13, 20:32)Martijn Wrote: [ -> ] (2012-06-13, 20:31)ronie Wrote: [ -> ] (2012-06-13, 02:34)bobrap Wrote: [ -> ]Should I delete my db and resrape?
question is will it keep the playdate or not when you do it this way?
(2012-06-13, 20:34)ronie Wrote: [ -> ] (2012-06-13, 20:32)Martijn Wrote: [ -> ] (2012-06-13, 20:31)ronie Wrote: [ -> ]that might fix things, but you'll loose the 'watched' status of your movies most likely.
It will keep that date so that won't work.
So it is start all over again (perhaps using export db and rescrape import watched status) or using an sql database browser to browse through the files table so you know which one screws up.
Perhaps adding a
Debug Log line in the script will also tell you which one
Thanks guys. I'm doing a complete windows/xbmc reinstall. See what happens. Is this an unfortunate glitch or something that may be fixed? If all is working correctly, does this script work with nightlies? Thanks again.
yeah, xbmc has stored an invalid playdate in the videodb.
not sure how/why it happened.
the script should run fine on nightlies though.
OK, great. I like using the nightlies and REALLY like this script. Just did the reinstall and I'll post if I get the error again. Thanks!
Is this the latest version...script.watchlist-0.1.14?
(2012-06-14, 22:14)bobrap Wrote: [ -> ]OK, great. I like using the nightlies and REALLY like this script. Just did the reinstall and I'll post if I get the error again. Thanks!
latest is 0.1.13
0.1.14 is the same but with some extra logging for troubleshooting purposes.
Hi there, getting the same error myself. Did you get it fixed? If so, how?
