(2013-02-13, 15:06)fungify Wrote: [ -> ]Just a minor update.
I've previously shown how to force MyPicsDB to update it's database automatically each night by using an external script. Unfortunately, this method is no longer quite as easy since Frodo introduced JSON-RPC for http requests. (Well - probably it's quite easy when you get the hang of it - but...).
I instead found another solution. I use the service The Scheduler (http://forum.xbmc.org/showthread.php?tid=144378) and create a custom built-in script with the following action:
RunScript(";C:\Users\Administrator\AppData\Roaming\XBMC\addons\plugin.image.mypicsdb\scanpath.py",--database)
Remember to update to your own path. I've chosen to run the script each night at 3:00 AM, so that every morning my Last Added-widget shows the images that was added the previous day.
Just a hint.
FFY
Call MyPicsDB 12.1.3 as follows:
RunScript("C:\Users\Administrator\AppData\Roaming\XBMC\addons\plugin.image.mypicsdb\scanpath.py",--refresh)
It is much faster
Hi Xycl.
This addon has been removed from XBMC.org repository ? I cannot find it any more :S
I have seen some times ago, when you ask for a repo push, a mail from Martijn asking you if this addon should be keeped in repo has development are stopped.
And your repo is empty, even after a forced refresh.
So how can users can install this addon ?
the repo from my signature works.
And yes due to different opinions about spare time hobbies between me and Martijn MyPicsDb was removed from official repo.
Xycl
OK I will make a new try (maybe it's because of my office proxy).
It's sad because I guess a lot of addons registered in XBMC official repo are not updated for a while so why MyPicsDB, which is quite stable, have to be removed
(2013-10-29, 11:52)Xycl Wrote: [ -> ]Hi,
Xycl
just so you know the line-endings rule is not my choice.
my opinion is that it doesn't matter but i not alone so consensus now is it should have consistent line ending
(2013-09-21, 15:09)Xycl Wrote: [ -> ]MyPicsDB 12.1.0
available in my repository.
It contains a lot of bug fixes introduced with the DB abstraction layer used for the MySql connectivity in version 12.0.0. ( which is and will forever be the last one in official XBMC repository
I thought that MyPicsDB was removed because of this sentence and because XYCL stop to maintain this addon.
But is it because XYCL develop under Windows and addon (and files) have to be pushed on repo with LINUX line-ending (Windows : CR LF / LINUX : LF
http://en.wikipedia.org/wiki/Newline) ?
(2013-10-29, 11:59)mikebzh44 Wrote: [ -> ]It's sad because I guess a lot of addons registered in XBMC official repo are not updated for a while so why MyPicsDB, which is quite stable, have to be removed
It has been removed because I decided to reject the rules I have to fulfull to submit to repo.
(2013-10-29, 12:34)mikebzh44 Wrote: [ -> ]But is it because XYCL develop under Windows and addon (and files) have to be pushed on repo with LINUX line-ending (Windows : CR LF / LINUX : LF http://en.wikipedia.org/wiki/Newline) ?
It not so easy.
I use Aptana Studio which is configured to save the files with Unix line endings.
But regularly I get patches from users. And frequently these patches contain CR/LF.
(2013-10-29, 12:22)Martijn Wrote: [ -> ]just so you know the line-endings rule is not my choice.
I know that.
That was the reason why I wrote that it doesn't make sense to discuss the rules.
Hi
I applaud you on the success of MyPDB. It is magnificent.
One question though is why thumbnails do not show up for my home videos when using NFS.
Most of my home videos have the *.mov extension. But I don't think that makes a difference as I have tried many other video formats
The thumbnails show up fine when using SMB.
The reason I ask is that I use NFS by default as I find I do not get buffering at all, using NFS, although I get buffering regularly when using SMB.
Does XBMC shows the thumbnails when using the "normal" picture file browser?
I don't think so because XBMC is responsible for showing the thumbnail.
MyPicsDB doesn't do anything except giving back the paths to XBMC.
You are 100% correct. When I use native XBMC pictures, no thumbnails show up when I use NFS but they do show up when using SMB.
Do you know why? Is it an XBMC issue or is it on my QNAP NAS end?
It's an XBMC issue.
XBMC automatically creates the thumbnails from media files.
I don't know why the network protocoll is important but obviously the NFS layer prevents XBMC from creating the thumbnails.
(2013-11-18, 23:33)espressologic Wrote: [ -> ]You are 100% correct. When I use native XBMC pictures, no thumbnails show up when I use NFS but they do show up when using SMB.
I use NFS (connecting to Synology) and with the native 'Pictures' section I get thumbnails. I'm running XBMC on Win7 x64, nothing fancy. I'll install this Add-On and let you know what I find... I've been meaning to get this installed since the native XBMC 'Pictures' sux.
