Hi Xycl
I did some rescans with MPD in Kodi Jarvis 16.0 beta 3 and 4. Did the rescan in both Win7 and Win10 environments on different computers.
In some cases the list view is generated/shown, but when I like to start the slideshow, Kodi stops working. This is what I found in the log
List views with a small amounth of pics (around 2500) are displayed OK
When the resultset of the list is above 4000 pics, then the slideshow is not starting
Have you seen this before? Do you need some more info?
Hopefully I can do some fixing
Thanks, Michel
Part of the Kodi log
18:57:31 T:9352 NOTICE: [My Pictures Database] line 118 in scanpath.py object VFSScanner.dispatcher >> Database refresh started
19:33:57 T:9352 ERROR: [My Pictures Database] line 858 in iptcinfo.py object iptcinfo.jpegScan >> Marker scan hit start of image data
19:33:57 T:9352 NOTICE: .
19:33:57 T:9352 ERROR: XFILE::CDirectory::Create - Error creating C:\
19:34:50 T:9352 ERROR: Previous line repeats 334 times.
19:34:50 T:9352 ERROR: [My Pictures Database] line 858 in iptcinfo.py object iptcinfo.jpegScan >> Marker scan hit start of image data
19:34:50 T:9352 NOTICE: .
19:34:50 T:9352 ERROR: XFILE::CDirectory::Create - Error creating C:\
19:35:28 T:9352 ERROR: Previous line repeats 217 times.
19:35:28 T:9352 ERROR: [My Pictures Database] line 858 in iptcinfo.py object iptcinfo.jpegScan >> Marker scan hit start of image data
19:35:28 T:9352 NOTICE: .
19:35:28 T:9352 ERROR: XFILE::CDirectory::Create - Error creating C:\
19:37:59 T:1000 ERROR: Previous line repeats 942 times.
19:37:59 T:1000 NOTICE: [My Pictures Database] line 86 in default.py object Main.get_args >> MyPicturesDB plugin called :
19:37:59 T:1000 NOTICE: [My Pictures Database] line 87 in default.py object Main.get_args >> sys.argv[0] = plugin://plugin.image.mypicsdb/
19:37:59 T:1000 NOTICE: [My Pictures Database] line 88 in default.py object Main.get_args >> sys.argv[2] =
19:38:09 T:5488 NOTICE: [My Pictures Database] line 86 in default.py object Main.get_args >> MyPicturesDB plugin called :
19:38:09 T:5488 NOTICE: [My Pictures Database] line 87 in default.py object Main.get_args >> sys.argv[0] = plugin://plugin.image.mypicsdb/
19:38:09 T:5488 NOTICE: [My Pictures Database] line 88 in default.py object Main.get_args >> sys.argv[2] = ?action=%27showtagtypes%27&name=%27Weergeven%20tags%27&tags=%27%27&viewmode=%27view%27
19:38:12 T:7516 NOTICE: [My Pictures Database] line 86 in default.py object Main.get_args >> MyPicturesDB plugin called :
19:38:12 T:7516 NOTICE: [My Pictures Database] line 87 in default.py object Main.get_args >> sys.argv[0] = plugin://plugin.image.mypicsdb/
19:38:12 T:7516 NOTICE: [My Pictures Database] line 88 in default.py object Main.get_args >> sys.argv[2] = ?action=%27showtags%27&method=%27tagtype%27&name=%27Trefwoorden%20(50%20tags)%27&page=%271%27&tagtype=%27Trefwoorden%27&viewmode=%27view%27
19:38:24 T:1568 NOTICE: [My Pictures Database] line 86 in default.py object Main.get_args >> MyPicturesDB plugin called :
19:38:24 T:1568 NOTICE: [My Pictures Database] line 87 in default.py object Main.get_args >> sys.argv[0] = plugin://plugin.image.mypicsdb/
19:38:24 T:1568 NOTICE: [My Pictures Database] line 88 in default.py object Main.get_args >> sys.argv[2] = ?action=%27showpics%27&method=%27tag%27&name=%27Fleur%20de%20Lastname%20(4791%20afbeeldingen)%27&page=%271%27&tag=%27Fleur%20de%20Lastname%27&tagtype=%27Trefwoorden%27&viewmode=%27view%27
19:38:35 T:3304 NOTICE: [My Pictures Database] line 86 in default.py object Main.get_args >> MyPicturesDB plugin called :
19:38:35 T:3304 NOTICE: [My Pictures Database] line 87 in default.py object Main.get_args >> sys.argv[0] = plugin://plugin.image.mypicsdb/
19:38:35 T:3304 NOTICE: [My Pictures Database] line 88 in default.py object Main.get_args >> sys.argv[2] = ?action=%27showpics%27&method=%27tag%27&name=%27Fleur%20de%20Lastname%20(4791%20afbeeldingen)%27&page=%271%27&tag=%27Fleur%20de%20Lastname%27&tagtype=%27Trefwoorden%27&viewmode=%27view%27
19:38:40 T:6672 ERROR: CJobWorker:
rocess error processing job cacheimage
19:38:40 T:7260 ERROR: Previous line repeats 3 times.
19:38:40 T:7260 ERROR: XFILE::CDirectory::GetDirectory - Unhandled exception
19:38:40 T:7260 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.image.mypicsdb/?action=%27showpics%27&method=%27tag%27&name=%27Fleur%20de%20Lastname%20(4791%20afbeeldingen)%27&page=%271%27&tag=%27Fleur%20de%20Lastname%27&tagtype=%27Trefwoorden%27&viewmode=%27view%27
19:38:50 T:7260 ERROR: Previous line repeats 259 times.
in an other log I discovered this line
16:17:36 T:3324 NOTICE: [My Pictures Database] line 86 in default.py object Main.get_args >> MyPicturesDB plugin called :
16:17:36 T:3324 NOTICE: [My Pictures Database] line 87 in default.py object Main.get_args >> sys.argv[0] = plugin://plugin.image.mypicsdb/
16:17:36 T:3324 NOTICE: [My Pictures Database] line 88 in default.py object Main.get_args >> sys.argv[2] =
16:17:37 T:2668 ERROR: CD3DTexture::Create - failed to create texture.
16:17:37 T:2668 ERROR: CRenderSystemDX::FinishCommandList - Failed to finish command queue.
16:17:37 T:2668 ERROR: DXGI_ERROR_DEVICE_REMOVED
16:17:43 T:2668 ERROR: CRenderSystemDX::CreateWindowSizeDependentResources - Failed to resize buffers (8007000E - E_OUTOFMEMORY (Onvoldoende opslagruimte beschikbaar om deze bewerking te voltooien.
