(2016-06-10, 03:13)twiseva Wrote: [ -> ] (2016-06-06, 15:01)peppe_sr Wrote: [ -> ] (2016-06-06, 12:03)Xycl Wrote: [ -> ]Please try version 13.3.8
it worked at first attempt
thanks
Peppe
So it seems that this same error has appeared for ma after updating to 13.3.8. See http://pastebin.com/raw/SHXqw4ZL. Looks basically the same. Prior to 13.3.8 all was well, afterwards get an error popup and this in the logs.
Did a quick hack that worked for me in default.py as follows. Excuse my hack as I have never programmed in Python.
95 # Altered change to remove the '&reload' and EVERYTHING after it
96 self.parm= self.parm.split('&reload=')[0]
To only remove &reload=xxx till next ampersand please use version 13.3.9
(2016-06-10, 15:29)Xycl Wrote: [ -> ]To only remove &reload=xxx till next ampersand please use version 13.3.9
Works great -- thanks @
Xycl.
Hey,
Before explaining why I came here, let me say that I'm a beginner with Kodi, and Kodi Add-ons.
So I installed Kodi, then your (marvelous) add-on on my old PC, which was running Windows before, and now Mint 17.3.
When I try to scan the folder that contains all my pics (about 20.000), PyPicsDB scans it, but stops after a while. It finds precisely 5311 pictures.
I tried 2 times with different installs, and the problem remains the same. I don't know if I'm just dumb and didn't find an obvious way to fix it, or if a problem exists in my files.
Thanks for reading this, and thanks for you work !
EDIT : It appears that one of my .jpg has been corruted, excluded it and re-scanning, I'll update in the morning
The easy way to understand your problem is through a debug log. Turn in on the settings, perform the scan and post the log on pastebin
Peppe
Thanks,
I checked myself in the log a bit, and it appears that one folder I was trying to scan contained corrupted files.
I excluded it in the search path, and it worked properly
Thanks for reading me, problem is fixed !
Hi I am new here
Hey , how to add music playlist to my album
I can't seem to be able to do it... Can't find that option anywhere
Please help with this stupid question
Thanks in advance for reply
Hi!
I've been using MyPicsDB for years now and a problem has been bothering me for months. I tag my photos using the face tagging feature of Picasa for Windows (which is configured to write face tags to the photos itself). I've 4000 pics of person X but MyPicsDB shows only about 400. The number shown by MyPicsDB varies whenever I go to Browse by Tags -> Person. Never figured out why. I've tried resetting the whole db and the problem is back after few weeks.
Today,
- I added only 1 folder to MyPicsDB with about 1000 photos. It found 411 photos of person X. Closed Kodi.
- Opened Picasa, tagged a new person (about 25 photos). Closed Picasa.
- Opened Kodi, MyPicsDB, scan for new/changed photos.
- After the scanning, new person has 25 photos, person X is down to 6 photos (all of which have new person as well).
If it helps, Picasa writes XMP-mwg-rs tags for faces.
Kindly fix the problem.
Hi Xycl!
It appears that more tags have a similar problem, not just the Person tag. I did an even more minimal test today. I added a single folder to MyPicsDB with 2 pictures. Both pics had the IPTC Caption/Description set to "Wow". I scanned them and I see 2 pics in the Browse by Tags -> Description -> Wow.
Then I edited one of the pictures and changed the caption to "Wowa". I scanned for new & changed pictures and MyPicsDB correctly shows 1 modified. Now Browse by Tags -> Description -> has only Wowa listed and Wow is missing.
However this does not happen always, sometimes both tags stayed - keep changing the caption from Wow to Wowa and back and the problem does happen soon enough. When it happens, I checked with a sqlite browser that the TagsInFiles.idTagContent has values which do not exist in TagContents table. It appears that instead of reusing the existing idTagType<->TagContent unique pair, a new record is added with a new idTagContent and the old pairs are deleted.
Is it a bug in the sqlite engine? I did my tests with v16.1 on Win7. I strongly believe it is the same problem on my main kodibuntu installation.
Hi Xycl!,
I have connected the Plugin to my MYSQL database which is working fine and also updating the database. When searching for picture with a certain tag I receive no results due to an SQL exception:
The Log says the following (Searching for Keyword Tag NRW):
16:38:08 T:12264 NOTICE: [My Pictures Database] line 86 in default.py object Main.get_args >> MyPicturesDB plugin called :
16:38:08 T:12264 NOTICE: [My Pictures Database] line 87 in default.py object Main.get_args >> sys.argv[0] = plugin://plugin.image.mypicsdb/
16:38:08 T:12264 NOTICE: [My Pictures Database] line 88 in default.py object Main.get_args >> sys.argv[2] = ?action=%27showpics%27&method=%27tag%27&name=%27NRW%20(32%20Pics)%27&page=%271%27&tag=%27NRW%27&tagtype=%27Keyword%27&viewmode=%27view%27
16:38:08 T:12264 NOTICE: [My Pictures Database] line 101 in default.py object Main.get_args >> action='showpics',method='tag',name='NRW (32 Pics)',page='1',tag='NRW',tagtype='Keyword',viewmode='view'
16:38:08 T:12264 NOTICE: [My Pictures Database] line 63 in MypicsDB.py function __init__ >> Used DB Backend = MySql
16:38:08 T:12264 NOTICE: Previous line repeats 1 times.
16:38:08 T:12264 ERROR: [My Pictures Database] line 274 in dbabstractionlayer.py object Database abstraction layer >> The request failed :
16:38:08 T:12264 ERROR: [My Pictures Database] line 275 in dbabstractionlayer.py object Database abstraction layer >> <type 'exceptions.Exception'> - 3065: Expression #1 of ORDER BY clause is not in SELECT list, references column 'MyPicsDB.f.ImageDateTime' which is not in SELECT list; this is incompatible with DISTINCT
16:38:08 T:12264 ERROR: [My Pictures Database] line 279 in dbabstractionlayer.py object Database abstraction layer >> SQL > SELECT distinct strPath,strFilename FROM Files f, TagContents tc, TagsInFiles tif, TagTypes tt WHERE f.idFile = tif.idFile AND tif.idTagContent = tc.idTagContent AND tc.TagContent = ? and tc.idTagType = tt.idTagType and length(trim(tt.TagTranslation))>0 and tt.TagTranslation = ? order by imagedatetime
16:38:08 T:12264 NOTICE: [My Pictures Database] line 285 in dbabstractionlayer.py object SQL request numvar = 1 content = NRW >> 4
16:38:08 T:12264 NOTICE: [My Pictures Database] line 285 in dbabstractionlayer.py object SQL request numvar = 2 content = Keyword >> 4
The MySQL server is the following: Server-Version: 5.7.13-0ubuntu0.16.04.2 - (Ubuntu)
Needless to say that with SQLLite it works without a problem:-)
Just discover that I can use a MySQL Database so I set up the addon to plug my my MySQL database and rescan my folders.
But when I restart Kodi, I have a MyPicsDB error :
18:53:09 T:1060 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.IndexError'>
Error Contents: list index out of range
File "C:\Kodi\16.1\portable_data\addons\plugin.image.mypicsdb\default.py", line 1940, in <module>
m.set_properties()
File "C:\Kodi\16.1\portable_data\addons\plugin.image.mypicsdb\default.py", line 1398, in set_properties
Collections = MPDB.cur.request( """SELECT COUNT(*) FROM collections""" )[0]
IndexError: list index out of range
Don't know if it's due to my MySQL version (running on my ReadyNAS-RN102 NAS) but table Collection is spelled with a upcase C.
After editing default.py :
Collections = MPDB.cur.request( """SELECT COUNT(*) FROM Collections""" )[0]
Everything is OK.
(2016-09-05, 18:59)mikebzh44 Wrote: [ -> ]Just discover that I can use a MySQL Database so I set up the addon to plug my my MySQL database and rescan my folders.
m.set_properties()
Everything is OK.
I don't think it's just you, I had the same error and editing my file fixed it as well. My database is running on Ubuntu Linux 14.04.
Thanks for posting your fix btw
Hi Xycl,
I started testing MyPicsDB to be able to show only a subset of the pictures with a corresponding rating, which Kodi unfortunately not supports.
With two images, I get the following error message:
12:20:17 T:140612934301440 NOTICE: [My Pictures Database] line 401 in scanpath.py object VFSScanner._get_metas()._get_xmp() >> Finished reading XMP tags
12:20:17 T:140612934301440 ERROR: Traceback (most recent call last):
12:20:17 T:140612934301440 ERROR: File "/storage/.kodi/addons/plugin.image.mypicsdb/scanpath.py", line 137, in dispatcher
12:20:17 T:140612934301440 ERROR: self._addpath(path, None, recursive, update)
12:20:17 T:140612934301440 ERROR: File "/storage/.kodi/addons/plugin.image.mypicsdb/scanpath.py", line 353, in _addpath
12:20:17 T:140612934301440 ERROR: self._addpath(dirname, folderid, True, update)
12:20:17 T:140612934301440 ERROR: File "/storage/.kodi/addons/plugin.image.mypicsdb/scanpath.py", line 288, in _addpath
12:20:17 T:140612934301440 ERROR: tags = self._get_metas(common.smart_unicode(localfile))
12:20:17 T:140612934301440 ERROR: File "/storage/.kodi/addons/plugin.image.mypicsdb/scanpath.py", line 427, in _get_metas
12:20:17 T:140612934301440 ERROR: if picentry['Image Rating'] is None or len(picentry['Image Rating']) == 0:
12:20:17 T:140612934301440 ERROR: TypeError: object of type 'int' has no len()
Any idea, what the problem could be? It reads more than 13000 pictures without any problems.
(2016-09-05, 18:59)mikebzh44 Wrote: [ -> ]After editing default.py :
Everything is OK.
I did this but my port is not default port and I still can not connect to mysql server.
Error log shows default port not my own port:
InterfaceError: 2003: Can't connect to MySQL server on '192.168.1.254:3306'
When I m at home I post full debug log
http://pastebin.com/1as5hEmC
