XBMC renames almost all of my movies so the title matches the IMDB-title (or any other scrape I use), but I want to see the filename instead.
How do I turn of the renaming function?
I'm using Eden.
(2012-06-13, 23:01)ypzilon Wrote: [ -> ]XBMC renames almost all of my movies so the title matches the IMDB-title (or any other scrape I use), but I want to see the filename instead.
I'm using Eden.
XBMC doesn't rename anything. It just shows you are more friendly way of showing the files.
can be changed:
xbmc settings -> video settings -> file lists -> "replace file names with library titles"
