Full Version: XBMC 11 VS NVIDIA 210
Hi experts,
I need your help!
Although I've never tried Linux before, I see the XbmcUbuntu and love it!
Now I want to install this in my computer but my Nvidia 210 don't work very well.
I have problem to install the driver when I run the driver I get the error "X server running" I searched in internet and the solution for that is execute the command:
sudo /etc/init.d/gdm stop when I did it, I got error: gdm doesn't exist
The other solutions are
sudo pkill X
Or
sudo killall Xorg
When I tried this the terminal is closed and I go back to xbmc login!
Please tell me How I can solve that!?
Thank you a lot everybody
Rafael
try
sudo stop lightdm
(2012-06-15, 15:54)FernetMenta Wrote: [ -> ]try
sudo stop lightdm
Shouldn't that be sudo service lightdm stop?
or you can just read the log and find out exactly which process is interfering.
nano /var/log/nvidia-installer.log
kill -9 <PID FROM LOG>
The other option (the one that i use and recommend) is to set the linux PC to runlevel 3 (command line multi-user)
with
sudo init 3
(this works on every linux i have tried)
When you are done, simply type
sudo init 5
to switch back to runlevel 5 (multiuser graphical mode)
It's worked perfectly but when I rebooted the system stop in the message: " Checking baterry state [Ok]
Is it possible I did anything wrong? what I can do to resolve this?
thank you everybody!
(2012-06-15, 17:11)Plaguester Wrote: [ -> ]
sudo stop lightdm
