is it possible to send commands to a pc from xbmc? for instance, can i send a command to launch the xlink kai engine on my pc? or perhaps send a command to close a program that is running on my pc?
it's possible via a python script. of course, you'd need some custom server listening on your pc that accepts these commands.
similar to the shutdown on lan script (i love that thing). can anyone help me find the wake up script? it suppose to be able to wake your computer.
(incognegro @ july 11 2005,20:46 Wrote:similar to the shutdown on lan script (i love that thing). can anyone help me find the wake up script? it suppose to be able to wake your computer.
search for 'wake on lan' in the python scripts development forum.....that should help you enough
or you could also try searching for it on the
xbmcscripts.com site...........and if you still have problems finding the script....
leep:
