During playback I lost my wired ethernet. I tried connecting with a static IP address and a dynamic IP address, both unsuccessful. The dynamic IP configuration yields an external address (169.254.01.59) which doesn't work.
There is no CrashReport around the time I lost my wired connection, and I see nothing obvious in the syslog.
Any help would be greatly appreciated.
A 169 address indicates a self assigned IP. So it appears as if your ATV2 is still functioning. I'd be looking elsewhere.... What modem/router are connected to? A switch? Cable come loose? etc..
I'm connected directly to a Actiontec MI424WR router. I've tested the cable connection, that's fine.
The wireless works fine, but playback buffers too much, I want to use my wired connection.
Never mind. I didn't read your first post properly where you said static ip did not work either. Did you gave a static IP that's within the range of the router?
Maybe also try and reboot. If it was due to some kind of crash, reboot might fix it.
(2012-06-16, 20:10)newatv2user Wrote: [ -> ]Maybe also try and reboot. If it was due to some kind of crash, reboot might fix it.
Surprisingly a reboot fixed it, surprisingly because a reboot never fixes much
Thanks for the tip
