2012-06-16, 18:46
I have searced through this forum and others and I cannot find a definitive guide on how to get DTS and AC3 to pass through to my Receiver.
When using Mplayer with following config file if the audio stream is AC3 or DTS my receiver will auto switch to that mode:
My hdmi card is an Nvidia GeForce 210 Silent. To get any kind of digital audio to my receiver my XBMC have to be the following:
Audio Output: HDMI
Speaker Configuration: 5.1
Boost Volume level on downmix: off
Dolby Digital (AC3) capable receiver: off
DTS capable receiver: off
Audio output device: Custom > Blank
Passthrough output device: HDA NVidia - hdmi - 7 (ALSA)
But this digital audio configuration only enables "MCH PCM 5.1" on my Onkyo receiver which I assume is "Multi-Channel 5.1 Pulse Code Modulation"
What is odd is when I enable either "Dolby Digital" or "DTS" capable receivers I get no audio and error "failed to
ALSA version is 1.0.25
XBMC version 11.0
I also tried this section "Default audio over HDMI"> http://wiki.xbmc.org/index.php?title=HOW...u/HOW-TO_4
I get the same results with "Dolby Digital" or "DTS" enabled no audio and error "failed to initialize audio device" or just MCH 5.1 PCM
I'm sure true AC3 and DTS is possible please help. here is my various hard ware info:
aplay -l
aplay -L
My local .mplayer/config to use pass through AC3 and DTS
Thanks in advance!
ao=alsa:device=hw=0.7
afm=hwdts,hwac3,
nolirc=yes
Audio Output: HDMI
XBMC version 11.0
aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: NVidia [HDA NVidia], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: NVidia [HDA NVidia], device 7: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 8: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 0: NVidia [HDA NVidia], device 9: HDMI 0 [HDMI 0]
Subdevices: 1/1
aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
hdmi_formatted
hdmi_complete
default
Playback/recording through the PulseAudio sound server
hdmi:CARD=NVidia,DEV=0
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=1
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=2
HDA NVidia, HDMI 0
HDMI Audio Output
hdmi:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
HDMI Audio Output
dmix:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
Direct sample mixing device
dmix:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
dmix:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
dmix:CARD=NVidia,DEV=9
HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
Direct sample snooping device
dsnoop:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
dsnoop:CARD=NVidia,DEV=9
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
Direct hardware device without any conversions
hw:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
hw:CARD=NVidia,DEV=9
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=3
HDA NVidia, HDMI 0
Hardware device with all software conversions
plughw:CARD=NVidia,DEV=7
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=8
HDA NVidia, HDMI 0
plughw:CARD=NVidia,DEV=9
HDA NVidia, HDMI 0
# Write your default config options here!
afm=hwdts,hwac3,
nolirc=yes
Thanks in advance!
