Full Version: Error opening mms stream
when trying to play a file with the url:
mms://www.sunzara.com/modules/sunzara_library/albums/bhangra+videos%2fsunzara%2ecom+%7c+desiinc%2eco%2euk+-+2dark+feat+mehsopuria+-+puth+punjab+da.wmv
from inside python (ooba script), i am unable to play it. the relevant portions of the log are attached. however, when i save the same url in a m3u file and open it through xbmc, it plays the video just fine. any clues? i am using the cvs from a few days ago.
first i thought it was %2f etc in the url, but then how come the same url string can be played from an m3u file? it's only when opened through python's interface to mplayer that the call is failing.
10-07-2005 14:38:05 info -->python initialized<--
10-07-2005 14:38:05 debug loadlibrarya('_sre.pyd')
10-07-2005 14:38:05 debug executing entrypoint at: 0xc2a3cb - dll: _sre.pyd
10-07-2005 14:38:05 debug loadlibrary('_sre.pyd') returning: 0xa6fcf0
10-07-2005 14:38:05 debug kernel32!getprocaddress(0xa6fcf0, 'init_sre') => 0xc2a120
10-07-2005 14:38:05 debug loadlibrarya('_ssl.pyd')
10-07-2005 14:38:05 debug executing entrypoint at: 0xc7e951 - dll: _ssl.pyd
10-07-2005 14:38:05 debug loadlibrary('_ssl.pyd') returning: 0xb1f210
10-07-2005 14:38:05 debug kernel32!getprocaddress(0xb1f210, 'init_ssl') => 0xc31aa0
10-07-2005 14:38:07 info                    <ooba>
10-07-2005 14:38:07 info reading: q:\scripts\ooba\settings.xml
10-07-2005 14:38:07 debug loadlibrarya('pyexpat.pyd')
10-07-2005 14:38:07 debug executing entrypoint at: 0x10c9c01 - dll: pyexpat.pyd
10-07-2005 14:38:07 debug loadlibrary('pyexpat.pyd') returning: 0xbf3870
10-07-2005 14:38:07 debug kernel32!getprocaddress(0xbf3870, 'initpyexpat') => 0x10b4540
10-07-2005 14:38:07 info reading menu.xml ...
10-07-2005 14:38:08 info activating window id: 13000
10-07-2005 14:38:09 info opening url:'http://www.sunzara.com/modules.php?op=mo...&f=albums'
10-07-2005 14:38:14 info opening url:'http://www.sunzara.com/modules.php?op=mo...f&f=albums  hangra+videos'
10-07-2005 14:38:19 info playing:mms://www.sunzara.com/modules/sunzara_library/albums/bhangra+videosunzara2.622271e-306com++desiinc1.453790e-305co2.359035e-306uk+-+2dark+feat+m
10-07-2005 14:38:19 info mplayer play:mms://www.sunzara.com/modules/sunzara_library/albums/bhangra+videos%2fsunzara%2ecom+%7c+desiinc%2eco%2euk+-+2dark+feat+mehsopuria+-+puth+punjab+da.wmv cachesize:2048
10-07-2005 14:38:19 info flipping bi-directional subtitles disabled
10-07-2005 14:38:19 debug   msg:enable mplayer osd
10-07-2005 14:38:19 debug   msg:mplayer dev-cvs-050614-18:52 &copy; 2000-2004 mplayer team
10-07-2005 14:38:19 debug   msg:cpu: intel celeron 2/pentium iii coppermine,geyserville
10-07-2005 14:38:19 debug   msgSadfamily: 6, stepping: 10)
10-07-2005 14:38:19 debug   msg:detected cache-line size is 32 bytes
10-07-2005 14:38:19 debug   msg:cpuflags:  mmx: 1 mmx2: 1 3dnow: 0 3dnow2: 0 sse: 0 sse2: 0
10-07-2005 14:38:19 debug   msg:compiled for x86 cpu with extensions:
10-07-2005 14:38:19 debug   msg: mmx
10-07-2005 14:38:19 debug   msg: mmx2
10-07-2005 14:38:19 debug   msg: sse
10-07-2005 14:38:19 debug   msg:79 audio & 187 video codecs
10-07-2005 14:38:20 debug   msg:mplayer_open_file(mms://www.sunzara.com/modules/sunzara_library/albums/bhangra+videos%2fsunzara%2ecom+%7c+desiinc%2eco%2euk+-+2dark+feat+mehsopuria+-+puth+punjab+da.wmv)
10-07-2005 14:38:20 info stating file mms://www.sunzara.com/modules/sunzara_library/albums/bhangra+videos%2fsunzara%2ecom+%7c+desiinc%2eco%2euk+-+2dark+feat+mehsopuria+-+puth+punjab+da.wmv.conf
10-07-2005 14:38:20 info stating file q:\system\players\mplayer\bhangra+videos%2fsunzara%2ecom+%7c+desiinc%2eco%2euk+-+2dark+feat+mehsopuria+-+puth+punjab+da.wmv.conf
10-07-2005 14:38:20 debug   msg:playing mms://www.sunzara.com/modules/sunzara_library/albums/bhangra+videos%2fsunzara%2ecom+%7c+desiinc%2eco%2euk+-+2dark+feat+mehsopuria+-+puth+punjab+da.wmv.
10-07-2005 14:38:20 debug   msg:auto open z:\subtitle
10-07-2005 14:38:20 debug   msg:protocol:mms
10-07-2005 14:38:20 debug   msg:open stream protocol:mms
10-07-2005 14:38:20 debug   msg:resolving http://www.sunzara.com for af_inet...
10-07-2005 14:38:20 debug   msg:connecting to server http://www.sunzara.com[http://www.sunzara.com]:1755 ...
10-07-2005 14:38:20 debug   msg:check if this is a playlist which requires -playlist option
example: mplayer -playlist <url>
10-07-2005 14:38:20 error cmplayer::openfile() mms://www.sunzara.com/modules/sunzara_library/albums/bhangra+videos%2fsunzara%2ecom+%7c+desiinc%2eco%2euk+-+2dark+feat+mehsopuria+-+puth+punjab+da.wmv failed
10-07-2005 14:38:20 debug freeing fs segment @ 0x913720
10-07-2005 14:38:30 info activating window id: 10020
10-07-2005 14:38:30 info                    </ooba>
10-07-2005 14:38:56 notice stop all
10-07-2005 14:38:56 notice stop time server
10-07-2005 14:38:56 notice stop dvd detect media
10-07-2005 14:38:56 notice stop fancontroller
10-07-2005 14:38:56 notice stop mplayer
10-07-2005 14:38:56 notice stop python
10-07-2005 14:38:56 notice unload skin
