Full Version: JSON javascript simple working example
Hi All,
Look I don't want to get flamed, but I am struggling to find a working json javascript example, something simple like power up, whatever it doesn't matter, just to get me started.
I cant seem to find any javascript libraries either that has working code attached?
If anyone can help I would appreciate it.
Have you looked at this page : http://wiki.xbmc.org/index.php?title=JSON-RPC_API/v4
It describes what to send using json, then you can use something like JQuery ajax calls described here http://api.jquery.com/jQuery.post/ to send the data over.
Thanks,
Eric.
