How are you sharing the userdata folder to XBMC?
Path subs (wiki) (will require each client to at least have the advancedsettings.xml file) or symbolic linking should work.
(2012-06-21, 21:51)Ned Scott Wrote: [ -> ]How are you sharing the userdata folder to XBMC? Path subs (wiki) (will require each client to at least have the advancedsettings.xml file) or symbolic linking should work.
I tried that but it seems to crash the server side.. I'll try it again later
I think i know the problem with symbolic linking, 'hard' symbolic linking doesn't work on xp
http://lime-technology.com/forum/index.p...ic=11473.0
That thread and some others said so...
Finally i solved it!
XP by default does not support symlink,
but by following this tutorial i managed to force it to share folder from ubuntu
http://schinagl.priv.at/nt/hardlinkshell...llext.html
Now i'm trying to add download button on contextual menu (right click), and removing the system menu..
I'd be very thankful if someone can point me which .cpp file i should edit..
