Full Version: no sound device found
just tried to use xbmc on debian sid runnning kernel 3.4.2.
In xfce and firefox I have got sound. Running xbmc within the xfce4 session or running it as standalone there are no audio or passthrough devices selectable (error: no device found message).
root@server:~# aplay -l
**** Liste der Hardware-Geräte (PLAYBACK) ****
Karte 0: Generic [HD-Audio Generic], Gerät 3: HDMI 0 [HDMI 0]
  Sub-Geräte: 1/1
  Sub-Gerät #0: subdevice #0
root@server:~# aplay -L
default
    Playback/recording through the PulseAudio sound server
hdmi:CARD=Generic,DEV=0
    HD-Audio Generic, HDMI 0
    HDMI Audio Output
lspci -v
*snip*
01:00.1 Audio device: Advanced Micro Devices [AMD] nee ATI Cedar HDMI Audio [Radeon HD 5400/6300 Series]
        Subsystem: Hightech Information System Ltd. Device aa68
        Flags: bus master, fast devsel, latency 0, IRQ 43
        Memory at feabc000 (64-bit, non-prefetchable) [size=16K]
        Capabilities: [50] Power Management version 3
        Capabilities: [58] Express Legacy Endpoint, MSI 00
        Capabilities: [a0] MSI: Enable+ Count=1/1 Maskable- 64bit+
        Capabilities: [100] Vendor Specific Information: ID=0001 Rev=1 Len=010 <?>
        Capabilities: [150] Advanced Error Reporting
        Kernel driver in use: snd_hda_intel
*snip*
lqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq AlsaMixer v1.0.25 qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x   Gerät: HD-Audio Generic        F1:  Hilfe                x
x    Chip: ATI R6xx HDMI        F2:  System-Informationen x
x Ansicht: F3:[Wiedergabe] F4: Aufnahme  F5: Alle                                                    F6:  Soundkarte auswählen x
x Element: S/PDIF        Esc: Beenden              x
x        x
x                                                             lqqk                                                             x
x                                                             xOOx                                                             x
x                                                             mqqj                                                             x
x                                                          < S/PDIF >                                                          x
Did I missed something? Help would be really nice. Smile
Sorry, I forgot to mention... I am running XBMC 11.0+git201205-dmo1 from debian-multimedia repo
# cat /proc/asound/card0/codec#0
Codec: ATI R6xx HDMI
Address: 0
AFG Function Id: 0x1 (unsol 0)
Vendor Id: 0x1002aa01
Subsystem Id: 0x00aa0100
Revision Id: 0x100200
No Modem Function Group found
Default PCM:
    rates [0x70]: 32000 44100 48000
    bits [0x2]: 16
    formats [0x1]: PCM
Default Amp-In caps: N/A
Default Amp-Out caps: N/A
GPIO: io=0, o=0, i=0, unsolicited=0, wake=0
Node 0x02 [Audio Output] wcaps 0x201: Stereo Digital
  Converter: stream=1, channel=0
  Digital: Enabled GenLevel
  Digital category: 0x2
Node 0x03 [Pin Complex] wcaps 0x400381: Stereo Digital
  Control: name="HDMI/DP,pcm=3 Jack", index=0, device=0
  Control: name="IEC958 Playback Con Mask", index=0, device=0
  Control: name="IEC958 Playback Pro Mask", index=0, device=0
  Control: name="IEC958 Playback Default", index=0, device=0
  Control: name="IEC958 Playback Switch", index=0, device=0
  Control: name="ELD", index=0, device=3
  Pincap 0x00000094: OUT Detect HDMI
  Pin Default 0x18560010: [Jack] Digital Out at Int HDMI
    Conn = Digital, Color = Unknown
    DefAssociation = 0x1, Sequence = 0x0
  Pin-ctls: 0x00:
  Unsolicited: tag=01, enabled=1
  Connection: 1
     0x02
Do you have a recent catalyst driver installed?
Thanks for your reply,
I were running fglrx in the past, but I want to get it running without beeing hooked on AMD's updates. So, no I don't have any version of catalyst driver installed. As you can see, intel-hda driver is loaded for the audio device.
Seems like nobody got a clue, I believe it's a bug in xbmc and will open one the next days.
