Full Version: Problems with undertexter.se
There seems to be something wrong with the parser for undertexter.se site. I do not get any results for HD movies. For example a search for "wrath of the titans" on the web site results in 9 hits but only the 4 first (SD) is shown in the xbmc gui. The subtitels that is not shown contains an icon indicating that it's a HD movie, this is probably the html that the parser does not handle.
Log: http://pastebin.com/9fzE1xHs
Compare with the website: http://www.undertexter.se/?group1=on&p=s...the+Titans
Otherwise, awesome plugin!
I just saw that I had written the wrong link to undertexter.se. Corrected the link. Is there any sollution for this problem?
I can just confirm that I have the same issue. No subtitles from the HD category of undertexter.se is visible from the subtitle plugin. However it might be better to post your logs in the XBMC Subtitles thread http://forum.xbmc.org/showthread.php?tid=126495 that is being monitored by the developer.
Thanks for the tip MutatedHero. I'll post in the other thread.
