Jeukku - you've got a rogue orphaned script from a
banned addon (wiki) still running in your system. You would be well advised to manually remove it using file explorer when Kodi is not running:
2020-05-24 02:57:52.000 T:9508 NOTICE: ADDON: script.module.tknorris.shared v0.0.23 installed
Just delete the folder
C:\Users\joona\AppData\Roaming\Kodi\addons\script.module.tknorris.shared and everything in it.
(2020-05-24, 10:54)DarrenHill Wrote: [ -> ]@Jeukku - you've got a rogue orphaned script from a banned addon (wiki) still running in your system. You would be well advised to manually remove it using file explorer when Kodi is not running:
Just delete the folder C:\Users\joona\AppData\Roaming\Kodi\addons\script.module.tknorris.shared and everything in it.
Removed that and bunch of other legacy add-ons. Didn't fix the problem. New log:
https://paste.kodi.tv/kotuwikuqo.kodi
Does Two-Factor Authentication affect logging in?
It won't play when I have a oauth token I get a
2020-06-02 22:50:35.350 T:140035328308992 ERROR: Twitch: Error |Gone| |[410] this API has been removed.|
I remembered I turned on 2fa and was wondering if they are related.
When watching a stream with 2.0 audio the audio flag isn't displayed in the Video OSD. The screenshot below is Arctic Horizon but I've checked Estuary and this also has the number of channels omitted. Is there an issue where the number of channels isn't being passed by the addon? Thanks.
Hello everyone!
I'm running Kodi on an iPad 3, iOS 9.3.6, and whenever I select a stream kodi crashes, here are the logs:
CrashReporter:
https://paste.kodi.tv/xafexesixa
kodi.log:
https://paste.kodi.tv/nositawuka.kodi
Not sure if it is the add-on or Kodi itself, but I wonder if you guys could give me some direction, as it only happens with Twitch.
Thanks a lot!
How do I get 1080p30?
I can get 1080p60 or 720p 30/60. Maybe not possible?
FXB78
Will look into it
dicelander
Need to enable debug logging, then restart and reproduce.
debug log (wiki)
snyft
You will only get qualities made available by Twitch and the broadcaster, if it's not available for that stream/vod there is nothing that can be done about that from the add-on.
Hello,
I have an issue with the Twitch Kodi app. When I try to watch VODS it reports an error "Playback failed". I can watch live channels but not vods. I am using Kodi 19 and the twitch app version is 2.5.10+matrix.1. Is this a global issue or is it just at my end ?
