Hey,
I'm new to xbmc and I really like the amount of add-ons, but there was one thing missing for me: A working twitch.tv plugin.
So i just built one by myself (with parts of the justin.tv plugin). It's already posted on the german website
http://www.xbmcnerds.com, but i wanted to present it to a bigger crowd.
So here it is:
https://github.com/StateOfTheArt89/Twitch.tv-on-XBMC/
The newest versions are to be found at github. The last release, considered stable, can be downloaded via the official xbmc repo (Just look for twitch.tv in the video add-on section).
If you experience any issues or want new features to be added, please tell via github or this forum.
Hope you guys like it
Edit 2013-03-21: removed the download link.
This needs to be bumped so that more people will find out about it.
Great plugin, however I do have one suggestion. I tried watching EVO on this, and because this defaults to highest quality I wasn't able to watch(720 required subscription). If you had an option to change the resolution, it would solve that issue.
Yea I'd like to see that as well.
I get user toke error when I try to use this plugin.
You'll get user token error if there are higher quality streams that require an account.
Sometimes when I click on streams, nothing happens, other times when I click on streams I either get an error telling me to check logs or gives me the user token error, even when I have my account info put in. Keep in mind from what I see, it only asks for the username and not the password.
I have a log for the 2 times I've tried click on a stream and nothing happens. Other info: XBMC version 11 on Apple TV 2. I've also deleted and tried to reinstall the plugin, this has not helped.
Here's the log:
http://xbmclogs.com/show.php?id=6430
Thanks for any support.
(2012-08-06, 01:57)liq456 Wrote: [ -> ]I get user toke error when I try to use this plugin.
This and similar errors should be fixed in the new version. It occoured, when you try to access "premium streams". Now the addon choses the best video quality available for free and plays the content anyway. These changes should be added in the official repository very soon.
I also added a "featured streams" section to the addon.
Hope you guys like it.
Cheers, StateOfTheArt
Just got an auto update, featured streams is a good addition. Good idea making best available option to bypass having to change it.
nice working good so far
only some complain XD,
i notice you change the icon scrap, now cover are good rez but is a mess,
covers are diff sizes and shapes,
and channels uses channel icon now, rez is good but ppl always fills it with no sense content.
any chance to get a option to use icons and covers how it was before ?
and if not ask too much, add description, channel name, number viewers ?
here is what im working on with your script
thx man, your script is awesome.
cheers.
(2012-09-10, 16:43)Middle Wrote: [ -> ]nice working good so far
cheers.
Yeah, you're right. I struggled with the images i got from the twitch.tv api (I wasn't sure if the different image formats were a result of the xbmc caching mechanism. i changed the selected images a lot, while i was testing the script.). Your screenshots look great - you can do a pull request on github if you want.
cool i will do that,
im coding one skin and i plan to offer good support for twitchtv
as soon i got it in alfa i will release, right now im working on learning better coding for build solid skin.
thx man
No streams work for me, log shows the following with any quality setting,
Note: I can only set my username, not my password and the 'following' directory is empty.
12:23:31 T:3013404432 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
12:23:31 T:2803891056 NOTICE: Creating InputStream
12:23:31 T:2803891056 ERROR: Unknown option jtv
12:23:31 T:2803891056 ERROR: Valid RTMP options are:
12:23:31 T:2803891056 ERROR: socks string Use the specified SOCKS proxy
12:23:31 T:2803891056 ERROR: app string Name of target app on server
12:23:31 T:2803891056 ERROR: tcUrl string URL to played stream
12:23:31 T:2803891056 ERROR: pageUrl string URL of played media's web page
12:23:31 T:2803891056 ERROR: swfUrl string URL to player SWF file
12:23:31 T:2803891056 ERROR: flashver string Flash version string (default LNX 10,0,32,18)
12:23:31 T:2803891056 ERROR: conn AMF Append arbitrary AMF data to Connect message
12:23:31 T:2803891056 ERROR: playpath string Path to target media on server
12:23:31 T:2803891056 ERROR: playlist boolean Set playlist before play command
12:23:31 T:2803891056 ERROR: live boolean Stream is live, no seeking possible
12:23:31 T:2803891056 ERROR: subscribe string Stream to subscribe to
12:23:31 T:2803891056 ERROR: token string Key for SecureToken response
12:23:31 T:2803891056 ERROR: swfVfy boolean Perform SWF Verification
12:23:31 T:2803891056 ERROR: swfAge integer Number of days to use cached SWF hash
12:23:31 T:2803891056 ERROR: start integer Stream start position in milliseconds
12:23:31 T:2803891056 ERROR: stop integer Stream stop position in milliseconds
12:23:31 T:2803891056 ERROR: buffer integer Buffer time in milliseconds
12:23:31 T:2803891056 ERROR: timeout integer Session timeout in seconds
12:23:31 T:2803891056 ERROR: CDVDPlayer::OpenInputStream - error opening [rtmp://199.9.255.175/app/jtv_epCaznvVkzqeI3gZ jtv=2f2221533bea39a977f038f447425474f5e42161:{\22swfDomains\22:\20[\22justin.tv\22,\20\22jtvx.com\22,\20\22xarth.com\22,\20\22twitchtv.com\22,\20\22twitch.tv\22,\20\22newjtv.com\22,\20\22jtvnw.net\22,\20\22wdtinc.com\22,\20\22imapweather.com\22,\20\22facebook.com\22,\20\22starcrafting.com\22],\20\22streamName\22:\20\22jtv_epCaznvVkzqeI3gZ\22,\20\22expiration\22:\201347708211.2663119,\20\22server\22:\20\22ams01-video3-2\22} swfUrl=http://www-cdn.jtvnw.net/widgets/live_embed_player.rda65b64e2bd9725f8b35318f027b6e52f6f78bb7.swf?channel=lethalfrag&referer=http://www.justin.tv/lethalfrag&userAgent=Mozilla/5.0%20(Windows%20NT%206.1;%20WOW64;%20rv:6.0)%20Gecko/20100101%20Firefox/6.0&channel=lethalfrag swfVfy=1 live=1 Pageurl=http://www.justin.tv/lethalfrag]
12:23:31 T:2803891056 NOTICE: CDVDPlayer::OnExit()
12:23:31 T:2803891056 NOTICE: CDVDPlayer::OnExit() deleting input stream
12:23:31 T:3013404432 ERROR: Playlist Player: skipping unplayable item: 0, path [plugin://plugin.video.twitch/?url=...&mode=play&channelname=lethalfrag]
12:23:31 T:3013404432 NOTICE: CDVDPlayer::CloseFile()
12:23:31 T:3013404432 NOTICE: DVDPlayer: waiting for threads to exit
12:23:31 T:3013404432 NOTICE: DVDPlayer: finished waiting
12:23:31 T:3013404432 ERROR: Unable to open audio mixer
(2012-09-15, 12:25)kingmob Wrote: [ -> ]No streams work for me, log show's the following with any quality setting,
The plugin only needs your username to get the streams you "follow". (So thats right
It seems to be a problem with librtmp (maybe a old version?). Which version of xbmc are you using and which os?
(2012-09-15, 12:33)StateOfTheArt Wrote: [ -> ]The plugin only needs your username to get the streams you "follow". (So thats right
Using xbmcbuntu. So that's ubuntu 12.04 with xbmc Eden I believe.
[edit]Tried updating, did not make any difference
[edit2]Tried compiling from git source and that appears to have solved the problem, thanks
. Still don't see the channels I follow though
