2005-07-12, 14:00
i have already recompiled 3 times and deleted all previous cvs stuff, deleted all the settings, and xbmc still freezes at startup
also, i can't ftp to my xbox after this happens, or ping it, or anything
Quote:27-12-2003 03:36:00 notice q is mapped to:harddisk0\partition1\apps\xbmc
27-12-2003 03:36:00 notice starting xboxmediacenter. built on jul 11 2005
27-12-2003 03:36:00 debug setting resolution 0
27-12-2003 03:36:00 debug we set resolution 0
27-12-2003 03:36:00 info load language file:q:\language\english\strings.xml
27-12-2003 03:36:01 notice loaded q:\system\players\mplayer\iso639-1.xml
27-12-2003 03:36:01 notice loaded q:\system\players\mplayer\iso639-2.xml
27-12-2003 03:36:01 info load keymapping
27-12-2003 03:36:01 info loading q:\keymap.xml
27-12-2003 03:36:01 info checking skin version of: project mayhem iii
27-12-2003 03:36:01 info skin version is: 1.3
27-12-2003 03:36:01 info gui format 1920x1080 1080i 16:9
27-12-2003 03:36:01 info gui screen offset (0,0)
27-12-2003 03:36:01 info install unhandled exception filter
27-12-2003 03:36:01 info creating subdirectories
27-12-2003 03:36:01 info thumbnails folder:q:\thumbs
27-12-2003 03:36:01 info shortcuts folder:q:\shortcuts
27-12-2003 03:36:01 info albums folder:e:\apps\albums
27-12-2003 03:36:01 info recording folder:q:\recordings
27-12-2003 03:36:01 info screenshots folder:q:\screenshots
27-12-2003 03:36:01 info subtitle folder:q:\subtitles
27-12-2003 03:36:01 notice initialize assignment:[dash] network ip:[192.168.0.3] netmask:[255.255.255.0] gateway:[192.168.0.1] nameserver:[0.0.0.0]
27-12-2003 03:36:01 warning not initializing network, using settings as they are setup by dashboard
27-12-2003 03:36:01 info init network
27-12-2003 03:36:01 info get local ip address:
27-12-2003 03:36:04 info ip adres:192.168.0.27
27-12-2003 03:36:04 notice start ftpserver
27-12-2003 03:36:04 notice start led control
27-12-2003 03:36:04 notice dim lcd on playback
27-12-2003 03:36:04 notice checking the date!
27-12-2003 03:36:04 notice - current date is: 27-12-2003
27-12-2003 03:36:04 notice start dvd mediatype detection
27-12-2003 03:36:04 notice initializing playlistplayer
27-12-2003 03:36:04 info lcd not used
27-12-2003 03:36:04 notice start fancontroller
27-12-2003 03:36:04 notice load default skin:[project mayhem iii]
27-12-2003 03:36:04 info load skin from:q:\skin\project mayhem iii
27-12-2003 03:36:04 info delete old skin...
27-12-2003 03:36:04 info default 4:3 resolution directory is q:\skin\project mayhem iii\pal
27-12-2003 03:36:04 info default 16:9 resolution directory is q:\skin\project mayhem iii\pal16x9
27-12-2003 03:36:04 info skin version is: 1.3
27-12-2003 03:36:04 info load fonts for skin...
27-12-2003 03:36:04 info loading fonts from q:\skin\project mayhem iii\1080i\font.xml
27-12-2003 03:36:04 info load font:font18 path:q:\skin\project mayhem iii\fonts\common-font18.xpr
27-12-2003 03:36:04 error failed to load load font:font18 path:q:\skin\project mayhem iii\fonts\common-font18.xpr
27-12-2003 03:36:04 info load font:font18 path:q:\media\fonts\common-font18.xpr
27-12-2003 03:36:04 error failed to load load font:font18 path:q:\media\fonts\common-font18.xpr
27-12-2003 03:36:04 error couldn't load font name:font18 file:q:\media\fonts\common-font18.xpr
27-12-2003 03:36:04 info load font:font13 path:q:\skin\project mayhem iii\fonts\common-720pfont14.xpr
27-12-2003 03:36:04 info load font:font14 path:q:\skin\project mayhem iii\fonts\common-font18.xpr
27-12-2003 03:36:04 error failed to load load font:font14 path:q:\skin\project mayhem iii\fonts\common-font18.xpr
27-12-2003 03:36:04 info load font:font14 path:q:\media\fonts\common-font18.xpr
27-12-2003 03:36:04 error failed to load load font:font14 path:q:\media\fonts\common-font18.xpr
27-12-2003 03:36:04 error couldn't load font name:font14 file:q:\media\fonts\common-font18.xpr
27-12-2003 03:36:04 info load font:font64 path:q:\skin\project mayhem iii\fonts\common-font64.xpr
27-12-2003 03:36:04 error failed to load load font:font64 path:q:\skin\project mayhem iii\fonts\common-font64.xpr
27-12-2003 03:36:04 info load font:font64 path:q:\media\fonts\common-font64.xpr
27-12-2003 03:36:04 error failed to load load font:font64 path:q:\media\fonts\common-font64.xpr
27-12-2003 03:36:04 error couldn't load font name:font64 file:q:\media\fonts\common-font64.xpr
27-12-2003 03:36:04 info load font:matrix8 path:q:\skin\project mayhem iii\fonts\matrix8.xpr
27-12-2003 03:36:04 info load font:font04 path:q:\skin\project mayhem iii\fonts\common-font18.xpr
27-12-2003 03:36:04 error failed to load load font:font04 path:q:\skin\project mayhem iii\fonts\common-font18.xpr
27-12-2003 03:36:04 info load font:font04 path:q:\media\fonts\common-font18.xpr
27-12-2003 03:36:04 error failed to load load font:font04 path:q:\media\fonts\common-font18.xpr
27-12-2003 03:36:04 error couldn't load font name:font04 file:q:\media\fonts\common-font18.xpr
27-12-2003 03:36:04 info load font:font15 path:q:\skin\project mayhem iii\fonts\common-font15.xpr
27-12-2003 03:36:04 error failed to load load font:font15 path:q:\skin\project mayhem iii\fonts\common-font15.xpr
27-12-2003 03:36:04 info load font:font15 path:q:\media\fonts\common-font15.xpr
27-12-2003 03:36:04 error failed to load load font:font15 path:q:\media\fonts\common-font15.xpr
27-12-2003 03:36:04 error couldn't load font name:font15 file:q:\media\fonts\common-font15.xpr
27-12-2003 03:36:04 info load font:font10 path:q:\skin\project mayhem iii\fonts\common-720pfont14.xpr
27-12-2003 03:36:04 info load font:font101 path:q:\skin\project mayhem iii\fonts\common-720pfont14.xpr
27-12-2003 03:36:04 info load font:font12 path:q:\skin\project mayhem iii\fonts\common-720pfont14.xpr
27-12-2003 03:36:04 info load font:fontkb path:q:\skin\project mayhem iii\fonts\common-720pfont14.xpr
27-12-2003 03:36:04 info load font:special12 path:q:\skin\project mayhem iii\fonts\special-normal-pal.xpr
27-12-2003 03:36:04 info load font:special13 path:q:\skin\project mayhem iii\fonts\special-bold-pal.xpr
27-12-2003 03:36:04 info load new skin...
27-12-2003 03:36:04 info loading skin file: home.xml
27-12-2003 03:36:04 info loading references file: q:\skin\project mayhem iii\pal16x9\references.xml
27-12-2003 03:36:04 info loading skin file: myprograms.xml
27-12-2003 03:36:04 info loading skin file: mypics.xml
27-12-2003 03:36:04 info loading skin file: filemanager.xml
27-12-2003 03:36:04 info loading skin file: myvideo.xml
27-12-2003 03:36:04 info loading skin file: myvideogenre.xml
27-12-2003 03:36:04 info loading skin file: myvideoactors.xml
27-12-2003 03:36:04 info loading skin file: myvideoyear.xml
27-12-2003 03:36:04 info loading skin file: myvideotitle.xml
27-12-2003 03:36:04 info loading skin file: settings.xml
27-12-2003 03:36:04 info loading skin file: myvideoplaylist.xml
27-12-2003 03:36:04 info loading skin file: settingssysteminfo.xml
27-12-2003 03:36:04 info loading skin file: dialogalbuminfo.xml
27-12-2003 03:36:04 info loading skin file: dialogscriptinfo.xml
27-12-2003 03:36:04 info loading skin file: settingsprofile.xml
27-12-2003 03:36:04 info loading skin file: dialogyesno.xml
27-12-2003 03:36:05 info loading skin file: dialogprogress.xml
27-12-2003 03:36:05 info loading skin file: dialogvolumebar.xml
27-12-2003 03:36:05 info loading skin file: dialogseekbar.xml
27-12-2003 03:36:05 info loading skin file: dialogkaitoast.xml
27-12-2003 03:36:05 info loading skin file: dialognumeric.xml
27-12-2003 03:36:05 info loading skin file: dialoggamepad.xml
27-12-2003 03:36:05 info loading skin file: dialogsubmenu.xml
27-12-2003 03:36:05 info loading skin file: dialogbuttonmenu.xml
27-12-2003 03:36:05 info loading skin file: dialogcontextmenu.xml
27-12-2003 03:36:05 info loading skin file: dialogmusicscan.xml
27-12-2003 03:36:05 info loading skin file: playercontrols.xml
27-12-2003 03:36:05 info loading skin file: musicosd.xml
27-12-2003 03:36:05 info loading skin file: musicosdvissettings.xml
27-12-2003 03:36:05 info loading skin file: visualisationpresetlist.xml
27-12-2003 03:36:05 info loading skin file: mymusicplaylist.xml
27-12-2003 03:36:05 info loading skin file: mymusicsongs.xml
27-12-2003 03:36:05 info loading skin file: mymusicnav.xml
27-12-2003 03:36:05 info loading skin file: mymusictop100.xml
27-12-2003 03:36:05 info loading skin file: dialogselect.xml
27-12-2003 03:36:05 info loading skin file: dialogok.xml
27-12-2003 03:36:05 info loading skin file: dialogfilestacking.xml
27-12-2003 03:36:05 info loading skin file: dialogvideoinfo.xml
27-12-2003 03:36:05 info loading skin file: musicoverlay.xml
27-12-2003 03:36:05 info loading skin file: settingsuicalibration.xml
27-12-2003 03:36:05 info loading skin file: settingsscreencalibration.xml
27-12-2003 03:36:05 info loading skin file: settingscategory.xml
27-12-2003 03:36:05 info loading skin file: videooverlay.xml
27-12-2003 03:36:05 info loading skin file: videofullscreen.xml
27-12-2003 03:36:05 info loading skin file: myscripts.xml
27-12-2003 03:36:05 info loading skin file: musicvisualisation.xml
27-12-2003 03:36:05 info loading skin file: slideshow.xml
27-12-2003 03:36:05 info loading skin file: videoosd.xml
27-12-2003 03:36:05 info loading skin file: myweather.xml
27-12-2003 03:36:05 info loading skin file: dialoginvite.xml
27-12-2003 03:36:05 info loading skin file: dialoghost.xml
27-12-2003 03:36:05 info loading skin file: dialogkeyboard.xml
27-12-2003 03:36:05 info loading skin file: mybuddies.xml
27-12-2003 03:36:05 info loading skin file: pointer.xml
27-12-2003 03:36:05 info loading skin file: dialogmutebug.xml
27-12-2003 03:36:05 info loading user windows q:\skin\project mayhem iii\pal16x9\custom*.xml
27-12-2003 03:36:05 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom1.xml
27-12-2003 03:36:05 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom2.xml
27-12-2003 03:36:05 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom3.xml
27-12-2003 03:36:05 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom4.xml
27-12-2003 03:36:05 info loading skin file: q:\skin\project mayhem iii\pal16x9\custom5.xml
27-12-2003 03:36:05 info initialize new skin...
27-12-2003 03:36:05 info loading q:\skin\project mayhem iii\sounds\sounds.xml
27-12-2003 03:36:05 info skin loaded...
27-12-2003 03:36:05 info initializing skin
27-12-2003 03:36:05 info kaiclient: instantiating...
27-12-2003 03:36:05 debug udpclient: creating udp socket...
27-12-2003 03:36:05 debug udpclient: setting broadcast socket option...
27-12-2003 03:36:05 debug udpclient: setting non-blocking socket options...
27-12-2003 03:36:05 debug udpclient: spawning listener thread...
27-12-2003 03:36:05 debug udpclient: ready.
27-12-2003 03:36:05 info kaiclient: ready.
27-12-2003 03:36:05 notice kaiclient: discovering kai engine via udp broadcast.
27-12-2003 03:36:06 info activating window id: 10000
27-12-2003 03:36:06 info removing tempfiles
27-12-2003 03:36:06 info checking bookmarks for special directories
27-12-2003 03:36:06 fatal unknown exception code (0xe06d7363)
at 0x00142c0e
