Full Version: Running XBMCuntu permanently from the SD Card
I must be missing something here. Clearly I can boot XBMC from an SD card. But I lose the settings every time I reboot.
Question:
1. Can I run XBMCUnbtu without an HDD or SSD ?
2. Can I avoid reconfiguring every time I reboot ? If so. how ?
You want to image the XBMCbuntu installer on one USB drive/SD card/optical disk, then install to the SD card you want to actually use. If you image XBMCbuntu directly to the drive you want to use then I believe it won't bother saving things. (I think. I could be mixing things up here.)
you can do this with unetbootin and set a persistance file.
