Full Version: [request] Roosterteeth.com addon
Pages: 1 2
As a dev of a playonscript for Red Vs Blue (that I am letting die because of this) the reason for the trending was a Monday with a new episode coming (6/25/12 was a monday) and why people couldn't recreate the problem the next day. My script doesn't work monday's when a new episode is going to hit and if you go to the main roosterteeth page on a monday, you'll find that it's different.
I don't know if it's getting /.'d or they just do something different because an upload is incoming or what, but trending is what you get monday's with a new episode. Just a heads up, and I don't think there is anything you can do to change it.
Will be DL'ing and testing this out soon.
EDIT: Ok re-reading some of this not sure I made sense. I'm assuming an addon for XBMC works similar to PlayOn in that it grabs the HTML. When it's Monday and a new Episode, RT changes something or because of /. effect, you don't get the expected HTML of the pages. It seems to ALWAYS replace more with trending. ie: http://roosterteeth.com/archive/?id=1344&v=more&s=8 becomes http://roosterteeth.com/archive/?id=1344&v=trending&s=8 on it's own. It's hard to show when it's not monday/new episode but anyways hope that explains it better.
That would make sense. So it's primarily an issue during the RvB season?
Well I guess it depends, if it's more of a /. effect, then prolly just RvB season, if it's how they change the website in prep for uploading then the day any new show episode is uploaded (they have a few now not just RvB).
This is not working for me. Clicking an episode just says working for like 2 seconds then back to episode list.
Ahh mostly Season 10 at least. If it's like my playon script, seaon 8/9 will be messed also. As for some reason blip.tv marks certain episodes as private. Even random ones within a season. I don't know if this is RT when uploading or Blip.tv.
For instance:
if you go to season 10 episode 7. If you have flashblock, you can mouse over the flash thing. In that URL is a number, which if you do blip.tv/archive/-that number, it will bring you to http://blip.tv/red-vs-blue/red-vs-blue-s...-7-6257429 and saying marked private.
Here is an update -> http://divingmules-repo.googlecode.com/f...-0.0.2.zip
This fixes an issue where occasionally we would get a subtitle file instead of the video file. Also some videos are marked sponsor only, I don't know a way around this but you will be notified if this is the case.
Let me know of any issues.
(2012-07-26, 04:21)dardack Wrote: [ -> ]For instance:
I'm guessing maybe you can't watch directly from blipHuh, It seems to be okay from the addon.
(2012-07-26, 14:54)divingmule Wrote: [ -> ]I'm guessing maybe you can't watch directly from blipHuh, It seems to be okay from the addon.
Just DL'd new one. Have you tried Season 10 any episodes? Sure season 1/2/3/4 work but Season 10 def doesn't work. I didn't try 8/9.
Now is there a way an addon can grab the original file like FlashGot addon for firefox?
Everything plays fine for me, could you pastebin a xbmc.log after a video fails to play?
http://pastebin.com/RCYLsZfC
Copying the URL from the Blip.tv in the log, It plays in chrome fine. Not sure what's wrong.
From your log -
NOTICE: DVDPlayer: Opening: http://blip.tv/file/get/Redvsblue-RedVsBlueSeason10Episode8818.srt
It's trying to play a subtitle file, notice the .srt extension. I don't think that is possible with version 0.0.2. Maybe something went wrong when updatingHuh
I would uninstall, then check ~/.xbmc/addons/packages/ and remove any roosterteeth zip. Then download and install again.
OK I'll try that tonite. TY. Missing my RT fix.
BTW does this grab the HD version (season 10 at least has a HD version) or only SD?
In the add-on settings, select high, if there's a HD version it should play it.
The add-on is now available from the main XBMC.org repository.
Looks like the python parser is having a problem with the site when using Kodi 14. Not sure if this is part of a bigger problem.
http://xbmclogs.com/show.php?id=300219
edit: for comparison, here's XBMC 13.2 loading the same site. http://xbmclogs.com/show.php?id=300224
Pages: 1 2
