Full Version: My HTPC media center miniITX ASUS + Koolance water blocks
Project Name “Silver spiders”
Primary system:
Case - Thermaltake DH 202 http://thermaltakeusa.com/Product.aspx?C=1319&ID=1878
Motherboard - ASUS F1A75-I DELUXE http://www.asus.com/Motherboards/AMD_Soc...5I_DELUXE/
Processors - AMD A8-3870K APU http://shop.amd.com/us/All/Detail/Proces...870WNGXBOX
Memory - Corsair Vengeance Black 8GB http://www.corsair.com/en/memory-by-prod...866c9.html
Video Card - Asus Radeon HD 7850 http://www.asus.com/Graphics_Cards/AMD_S...50DC22GD5/
Water cooling system:
Koolance GPU-220 (Vid/MB) http://koolance.com/index.php?route=prod...uct_id=966
Koolance CPU-370 (CPU) http://koolance.com/cpu-370-processor-wa...%20CPU-370
Koolance CHC-125 (MB) http://koolance.com/chc-125-motherboard-...ater-block
Koolance MVR-40 (MB VReg) http://koolance.com/mvr-40-motherboard-vreg-water-block
Koolance RP-401X2 Single 5.25" Reservoir http://koolance.com/index.php?route=prod...ct_id=1204
Koolance Water Pump PMP-400 High-flow Pump http://koolance.com/index.php?route=prod...uct_id=334
Koolance Radiator, 1x120mm 20-FPI Copper http://koolance.com/index.php?route=prod...ct_id=1215
Koolance Radiator, 2x120mm 20-FPI Copper http://koolance.com/index.php?route=prod...ct_id=1090
Koolance RAM-33 X 2 (Single DDR/DDR2/DDR3/SD) http://koolance.com/index.php?route=prod...th=0_29_56
Koolance Video RAM Heat Sinks EOL http://koolance.com/video-ram-heat-sinks
Others components :
Lamptron Fan Controller FC5V2 http://www.lamptron.com/products/view/Fa...ller_FC5V2
Fan – 3 x Scythe Gentle Typhoon 120mm 1850rpm http://www.scythe-eu.com/en/products/fan...20-mm.html
10 x WD Elements Desktop 2TB USB2.0 http://www.wdc.com/en/products/products.aspx?id=260
Logitech diNovo Mini™ http://www.logitech.com/en-gb/keyboards/keyboards/3848
Logitech Harmony® 300i Remote http://www.logitech.com/en-gb/remotes/un...motes/6812
Insert water block to motherboard:
Prewiew:
OK it looks the mutts nuts Big Grin but isn't it just a tad OTT?
are you a plumber by trade? Wink
the reply removed
Logitech diNovo Mini™, Logitech Harmony® 300i Remote
http://img-fotki.yandex.ru/get/5301/1567...1cf38_orig
11x WD ELEMENTS DESKTOP 2TB, 10x LogiLink USB 2.0 HUB
http://img-fotki.yandex.ru/get/5300/1567...dc4bb_orig
http://img-fotki.yandex.ru/get/6314/1567...99391_orig
That is just totally awesome!
(2012-06-23, 18:58)Dave_qp Wrote: [ -> ]OK it looks the mutts nuts Big Grin but isn't it just a tad OTT?
Its like buying a supercar just to drive to the shops, you don't need it but it does look cool.
David
A very sexy build. I love WC setups but I just couldn't justify it for my HTPC. It runs almost silently on air. Still, congrats on the neat build!
This is the three inch porterhouse of HTPCs. LOL.
I'm wondering how long it will be before you crack open those externals and build a cold-fusion powered unRAID box.
You say OTT...
But for a nice quiet COOL htpc why not?!
I know my HTPC runs a 35w cpu and still gets bloody hot.
Then the fans come on full on, so makes quite a bit of noise
As its in a TV Unit shelf. So im now thinking of WC my htpc!
(2012-06-27, 16:14)DavidT99 Wrote: [ -> ]
David
David......different people like different thing.......it doesn't mean that other cheaper option cannot achieve the same thing......it just mean that OP want his HTPC this way.......
To OP.....it looks awesome bud....!
(2012-06-27, 18:30)bluray Wrote: [ -> ]
David
I'm not knocking it, I too think it looks great, but should have been installed in a perspex case so that it can be seen!
Looks like a beast.
