Full Version: scripts not working
Im running XBMC 10.1 on WIndows XP SP3 with ATI 9600XT video card. The Youtube script and Canada on Demand script fail to load when I select them. Here is part of my log file.
16:53:17 T:3412 M:784445440 NOTICE: Starting XBMC, Platform: Windows XP Professional Service Pack 3 build 2600. Built on Mar 8 2011 (Git:e9e9099, compiler 1500)
16:53:17 T:3412 M:784445440 NOTICE: AMD Athlon™ XP 2500+
16:53:17 T:3412 M:784445440 NOTICE: Desktop Resolution: 1920x1080 32Bit at 60Hz
16:53:17 T:3412 M:784441344 NOTICE: Running with administrator rights
16:53:17 T:3412 M:784441344 NOTICE: special://xbmc/ is mapped to: C:\Program Files\XBMC
16:53:17 T:3412 M:784441344 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files\XBMC
16:53:17 T:3412 M:784441344 NOTICE: special://masterprofile/ is mapped to: C:\Documents and Settings\ox\Application Data\XBMC\userdata
16:53:17 T:3412 M:784441344 NOTICE: special://home/ is mapped to: C:\Documents and Settings\ox\Application Data\XBMC
16:53:17 T:3412 M:784441344 NOTICE: special://temp/ is mapped to: C:\Documents and Settings\ox\Application Data\XBMC\cache
16:53:17 T:3412 M:784441344 NOTICE: The executable running is: C:\Program Files\XBMC\XBMC.exe
16:53:17 T:3412 M:784441344 NOTICE: Log File is located: C:\Documents and Settings\ox\Application Data\XBMC\xbmc.log
16:53:17 T:3412 M:784441344 NOTICE: -----------------------------------------------------------------------
16:53:17 T:3412 M:784416768 NOTICE: Setup SDL
16:53:17 T:3412 M:784142336 NOTICE: Found screen: Plug and Play Monitor on ASUS A9600 Series , adapter 0.
16:53:17 T:3412 M:784138240 NOTICE: Primary mode: 1920x1080 @ 60.00 - Full Screen
16:53:17 T:3412 M:784134144 NOTICE: Additional mode: 320x200 @ 60.00 - Full Screen
16:53:17 T:3412 M:784150528 NOTICE: load settings...
16:53:17 T:3412 M:784084992 NOTICE: special://profile/ is mapped to: special://masterprofile/
16:53:17 T:3412 M:784076800 NOTICE: loading special://masterprofile/guisettings.xml
16:53:17 T:3412 M:783855616 NOTICE: Getting hardware information now...
16:53:17 T:3412 M:783855616 NOTICE: Checking resolution 12
16:53:17 T:3412 M:783843328 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
16:53:17 T:3412 M:783826944 NOTICE: Loaded playercorefactory configuration
16:53:17 T:3412 M:783818752 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
16:53:17 T:3412 M:783818752 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
16:53:17 T:3412 M:783818752 NOTICE: No advancedsettings.xml to load (special://masterprofile/advancedsettings.xml)
16:53:17 T:3412 M:783818752 NOTICE: Default DVD Player: dvdplayer
16:53:17 T:3412 M:783818752 NOTICE: Default Video Player: dvdplayer
16:53:17 T:3412 M:783810560 NOTICE: Default Audio Player: paplayer
16:53:17 T:3412 M:783851520 NOTICE: Loading media sources from special://masterprofile/sources.xml
16:53:20 T:3412 M:774795264 NOTICE: initializing playlistplayer
16:53:20 T:3412 M:774795264 NOTICE: DONE initializing playlistplayer
16:53:21 T:3412 M:766361600 NOTICE: initialize done
16:53:21 T:3412 M:766361600 NOTICE: Running the application...
16:53:21 T:3412 M:766341120 NOTICE: ES: Starting event server
16:53:21 T:3636 M:766271488 NOTICE: ES: Starting UDP Event server on 127.0.0.1:9777
16:53:21 T:3636 M:766267392 NOTICE: UDP: Listening on port 9777
16:53:28 T:3412 M:747380736 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 0
16:53:31 T:4040 M:745648128 NOTICE: -->Python Interpreter Initialized<--
16:53:33 T:3412 M:744771584 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 0
16:53:34 T:4040 M:743329792 ERROR: Error Type: exceptions.ImportError
16:53:34 T:4040 M:743329792 ERROR: Error Contents: No module named scanner
16:53:34 T:4040 M:743092224 ERROR: Traceback (most recent call last):
File "C:\Documents and Settings\ox\Application Data\XBMC\addons\plugin.video.canada.on.demand\default.py", line 11, in ?
from channels import *
File "C:\Documents and Settings\ox\Application Data\XBMC\addons\plugin.video.canada.on.demand\channels\ctv.py", line 1, in ?
from theplatform import *
File "C:\Documents and Settings\ox\Application Data\XBMC\addons\plugin.video.canada.on.demand\channels\theplatform.py", line 4, in ?
import simplejson
File "C:\Documents and Settings\ox\Application Data\XBMC\addons\script.module.simplejson\lib\simplejson\__init__.py", line 108, in ?
from decoder import JSONDecoder
File "C:\Documents and Settings\ox\Application Data\XBMC\addons\script.module.simplejson\lib\simplejson\decoder.py", line 7, in ?
from simplejson.scanner import make_scanner
ImportError: No module named scanner
16:53:34 T:3412 M:743190528 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.canada.on.demand/
16:53:34 T:3412 M:743190528 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.canada.on.demand/) failed
16:53:34 T:3412 M:743174144 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 0
16:55:09 T:3408 M:746434560 WARNING: Previous line repeats 1 times.
16:55:09 T:3408 M:746434560 NOTICE: -->Python Interpreter Initialized<--
16:55:10 T:3408 M:743874560 ERROR: Error Type: exceptions.ImportError
16:55:10 T:3408 M:743874560 ERROR: Error Contents: No module named scanner
16:55:10 T:3408 M:743641088 ERROR: Traceback (most recent call last):
import simplejson
16:55:10 T:3412 M:743665664 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.canada.on.demand/
16:55:10 T:3412 M:743665664 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.canada.on.demand/) failed
16:55:10 T:3412 M:743649280 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 0
16:57:16 T:3608 M:587960320 WARNING: Previous line repeats 1 times.
16:57:16 T:3608 M:587960320 NOTICE: -->Python Interpreter Initialized<--
16:57:17 T:3608 M:584388608 ERROR: Error Type: exceptions.ImportError
16:57:17 T:3608 M:584388608 ERROR: Error Contents: No module named scanner
16:57:17 T:3608 M:584155136 ERROR: Traceback (most recent call last):
import simplejson
16:57:17 T:3412 M:584183808 ERROR: XFILE::CDirectory::GetDirectory - Error getting plugin://plugin.video.canada.on.demand/
16:57:17 T:3412 M:584183808 ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.canada.on.demand/) failed
16:57:17 T:3412 M:584155136 WARNING: XFILE::CVideoDatabaseDirectory::GetLabel - Unknown nodetype requested 0
Any help is appreciated.
-jeff
Removed the old installation and reinstalled and now it seems ok.
