Full Version: MCERemote do not map any changes
I use a Remote Control and the MCERemote addon.
I changed some keys in the past without any problems, but today i want to map the Context-Menu to the green button(sending "c") which is not working, i also tried to set some other working commands to blue, yellow and # button which is also not working.....
I tried to start XBMC as admin, with no success, reboot HTPC also made no change.
MCERemot is just ignoring my changes.
I use Eden 11.0, can anyone help me?
are you sure that your remote uses the ehome driver?
How can i find out if it does?
The only thing I know is that it worked several times in the past......
