2012-06-25, 11:19
Right, I've spent a while trying to work out what this might be, and I can't, so I'm just trying to gauge whether I'm the only person who gets this...
My hardware spec is a bog-standard Asrock ION330 (Atom 330, Nvidia ION, 2GB RAM), and whenever I try to watch live TV using either iPlayer or TVCatchup, it will play maybe 30 seconds, then buffer for a few, then maybe 30-60 seconds more, buffer, and so on. I thought initially it was a software problem, as this system started as XBMCLive a couple of years ago and has been hacked around and upgraded a few times, so over this weekend I did a clean install of Ubuntu 12.04 x64, layered XBMC on top (from the official universe repos), and configured it for the basics. However, I'm still getting the problem. I don't have a logfile handy but will get one tonight, however I do remember the type of message I was getting would be "asked for data packet, nothing available".
I don't believe this is a problem with my internet connection, as it's a rock-solid 12Mb/s (the line is actually capable of 18, the 12 is an ISP-level cap due to the package I pay for) and I don't have a problem using these services in a browser from my desktop computer upstairs. I do have a HE.net IPv6 tunnel enabled, however this is also advertised to my home LAN using radvd, so either both the HTPC and my desktop are using IPv6, or they're both using IPv4, and yet still one works and one doesn't. I also don't remember it happening with the Dharma release of XBMC (or if it did, it wasn't every time),
Does anyone else find their experience mirroring mine, and have you/how did you solve it?
Cheers!
Cheers!
