2012-06-25, 20:58
2012-06-25, 22:24
<orientation>vertical</orientation> ?
2012-06-25, 23:44
Haha
What I've meant to ask is how to make it vertically centered. It keeps sliding towards top of the screen when there are fewer items in it.
2012-06-26, 09:59
The context menu always opens in the center (both x and y) of the list it applies to. So you'd have to adjust your list height and posy in this case.
2012-06-26, 10:22
Use a series of slide animations based on the buttons visible?
eg
eg
PHP Code:
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1002)">Conditional</animation>
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1003)">Conditional</animation>
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1004)">Conditional</animation>
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1005)">Conditional</animation>
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1006)">Conditional</animation>
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1007)">Conditional</animation>
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1008)">Conditional</animation>
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1009)">Conditional</animation>
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1010)">Conditional</animation>
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1011)">Conditional</animation>
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1012)">Conditional</animation>
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1013)">Conditional</animation>
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1014)">Conditional</animation>
<animation effect="slide" end="0,-20" time="0" condition="Control.IsVisible(1015)">Conditional</animation>
2012-06-26, 11:29
(2012-06-26, 09:59)Big_Noid Wrote: [ -> ]The context menu always opens in the center (both x and y) of the list it applies to. So you'd have to adjust your list height and posy in this case.
Managed to override that with
<coordinates>
<system>1</system>
<origin x="729" y="210" />
</coordinates>
so it gets centered horizontally. It does not help with Y axis as height of the menu changes.
(2012-06-26, 10:22)Hitcher Wrote: [ -> ]Use a series of slide animations based on the buttons visible?
That seems as the only way to go although I'm not sure if it will prove as a good idea in the long run
