Full Version: Video on raspberry pi
Hello,
First of all I apologize for my English, I'm French!
I use xbmc (12 alpha 3) on the raspberry pi and I have a problem with the videos on my TV, when I watch a movie, the animation is strangely fluid to as if it had been filmed with a camcorder familial.Je n 'had no problem with xbmc 10 but it is true that I was going through the VGA input and now I use the HDMI input. Is there something I can do or just wait the futur development ?
Thanks,
Benoit
Do you have a tv that supports 120hz?
Thanks for your response!
I'm not sure that the TV supports 120hz.
Here's what I found on the data sheet (TV SHARP LC-40LE630E) :
LCD 102 cm (40 ") / LED / 100 Hz
and
1080p 50/60/24Hz
It seems that you are right, can we change this setting in xbmc?
Thanks,
Benoit
