Full Version: [RELEASE] Akinator.com
just a small add-on to play Akinator while watching your media.
Map this to a key (or use it with Commands) to play while in fullscreen mode:
RunPlugin(plugin://plugin.program.akinator_com)
You can install it from the xbmc.org eden repo.
cheers,
asde
Hi Asde,
Has this app been out of maintenance for some time?
Just asking because it is still in the official Repo and I decided to try it while browsing the new addon section on the website, but it seems to be broken?
(2013-11-22, 23:34)mayoman Wrote: [ -> ]Hi Asde,
Yes, seems to be broken because of site changes. Did not noticed that before. Currently working on multiple other projects, so the fix may take some time...
(2013-11-24, 16:38)AddonScriptorDE Wrote: [ -> ]Yes, seems to be broken because of site changes. Did not noticed that before. Currently working on multiple other projects, so the fix may take some time...
Thanks, thought that was probably it.
Had some fun with the kids with Akinator, but not the most important addon in the scheme of things. Big Grin
Btw, great work on the Netflix addon.
