Full Version: Tip ~ XBMC Server CPU Idle
Hello, hope you are all doing well. If you've noticed by now on Eden that the CPU idle is higher than viewing a movie, you'll be concerned about leaving the server on 24/7. Here's a tip: when you are not using your XBMC server just exit into the new desktop login screen instead of leaving it on the XBMC homescreen. 0% cpu idle there.
ps. I've done all that (dirty regions, vbsync only video, crossed fingers, etc)
is this for xbmbuntu? or?
unless xbmc continues running this kind of defeats the purpose of having a server on 24/7 anyways and you might as well shut it down.
