Full Version: Issues with most of my BD ISOs
I rip out the main movie using DVDFab while still keeping it in ISO format. This is my preferred method, and it works great for popcorn hours. Now that XBMC supports lossless and BD ISO I decided to give it a try, and I love it.. up until the point until I actually try to play stuff. I tried both the release, and the nightly build.
Here's my issues:
1) Subtitles on 50% of my ISOs disappear about .1 seconds after they show up.
2) The video quality is a night and day difference compare to my popcorn hour. Everything played on XBMC seems soft and blurry, i'm using the same display with the same settings to compare.
3) It doesn't seem to detect if a subtitle track is suppose to be ON by default. You can either have them on or off, if I have a BD ISO that specifies "I want subtitle track 2 on when the movie starts", it doesn't seem to do it.
4) If I set XBMC to match my refresh rate to the movie being played, the movie gets about 2FPS. I'm using a Sony HX929 and a GTX680, both are very high end.
I really want to get XBMC working without having to convert to MKV. I have over 50TB of ISOs on a home server, so I am not willing to convert to MKV when they already work on the popcorn hour. I enjoy XBMC interface much more and it allows me to use a much more powerful computer for playback then a popcorn hour, so I hope these problems are fixable. Any ideas?
Please try to play one of the iso files that give you problems and then post a link to your log file.
http://wiki.xbmc.org/index.php?title=Log_file
loglevel 1 (debug logging might be needed)
(2012-06-29, 14:18)MassIV Wrote: [ -> ]Please try to play one of the iso files that give you problems and then post a link to your log file.
Here's a log of kill bill, subtitles disappear instantly, looks blurry (like all my ISOs in XBMC).
http://www.mediafire.com/?gzx8bn5ntcuw14i
Sorry been busy. And you are going to need someone who knows more then me i think. So consider this just a bump.
1)Far as i can see, the subs might be disappearing too fast because of CDVDPlayerAudio:: Discontinuity problems and unsupported sample rate.
And that is just the best guess i have. So basically the subs lose track of sync because audio packets are dropped.
Try a nightly build to see if some dev has fixed it already. http://mirrors.xbmc.org/nightlies/
2) The blur: Post-processing settings? Off. Deinterlacing settings? Auto & best. And how blurry is blurry?
3) Subs ect can be set in the video OSD.
4) The refresh rate problem is probably because of unsupported frame rates on your tv. So you can't use that setting (instead match it to tv).
I also have the subtitle problem in some, but not all, movies.
In addition, I also have another issue: In certain movies, Tron: Legacy (3D) and Coraline (3D), the movies play just fine up to a certain point and then it jumps forward several minutes. It's not a random glitch because it always happens at the same spots. I've played both movies in MPC-HC without any problems to rule out file corruptions.
