Full Version: [Request Box set Artwork]
I dont know whether this is possible but, I for one would readily use it. It would be a godsend for people who use box sets (i have about 103)
Usually if I have to re-install or create a new database all the custom thumbs and fanarts for the box sets are lost
My idea would be to have all your thumbs in a folder named the same as the box set and then the same for fanarts
You could run the program to update your artwork effectively and quickly, also if no artwork found it would just use the default.
That way if you needed to reinstall anything or have a corrupted database you could simply re-use the artwork with one click
Any ideas for this, I am not a coder but work with graphics and would find this useful.
