Full Version: [Solved] Stacked movie scrapes ok but playback 1st file only
I'm having an issue with playback of stacked files.
I have a movie split across 2 discs (hence the 2 files). The files are in a single folder named as the movie.
P:\Blu-Ray\New Rips\mkv\The Lord Of The Rings - The Fellowship Of The Ring (2001)\
~> The Lord Of The Rings - The Fellowship Of The Ring (2001) Pt 1.mkv
~> The Lord Of The Rings - The Fellowship Of The Ring (2001) Pt 2.mkv
As this is a blu-ray rip, I also have corresponding .idx and .sub files in the same directory.
For scraping, I use the option 'Movies are in separate folders that match the movie title'.
Scraping seems to have worked ok as the videodb.xml file contains the following entry for filenameandpath:
stack:///Volumes/Movies 2/Blu-Ray/Movies/The Lord Of The Rings - The Fellowship Of The Ring (2001)/The Lord Of The Rings - The Fellowship Of The Ring (2001) Pt 1.mkv , /Volumes/Movies 2/Blu-Ray/Movies/The Lord Of The Rings - The Fellowship Of The Ring (2001)/The Lord Of The Rings - The Fellowship Of The Ring (2001) Pt 2.mkv
However, the 2nd file doesn't play after the 1st has finished.
Here is the link to my xbmc.log. Note that I had to skip chapters and then ff x4 to get to the end of the 1st file quickly.
System Spec:
Mac Mini (2010)
2.4GHz Intel Core Duo
2GB 1067 MHz DDR3
GeForce 320M
Mac OSX 10.6.8
My media files are located on usb-attached external storage.
If any further information is required, please let me know.
Thanks in advance for any assistance in resolving this issue.
Edit: Not sure if it's relevant, but I'm using the Back Row skin
Try playing it from the actual videos window, not from recently added. Should then work fine.
Wow - thx for the quick reply.
Just tested and you're right - works fine if not selected from recently added.
Thanks again
Right - the problem is likely an issue with the skin - eg Confluence should work I think?
