Full Version: need to add more fans - confused
Hey all, I have a xbmc/serve box in the "man cave" part of the garage. I built it last fall and had no issues with it until a week ago when the temps in the midwest got 95+ for a few days. My Hard drives were getting too hot which I know is horrible for the life of the drive. I dont know much about fans as every other system ive built has come with them and have been no problem
I want to add some new/more fans and found this one http://www.newegg.com/Product/Product.as...6835185054
now im ok with it being loud but id like to slow the fan during the colder months. Is there a way to control the speed of the fans?
I have the antec 300 case with plenty of fan space built in now I just need to right ones.
thanks for any help!
Do you have an open 5.25" bay in your 300?
If so something like this
http://www.newegg.com/Product/Product.as...6811992007
would be a good option for your case and would allow you to control multiple fans.
If memory serves me correctly the Antec 300 has 2 in the front, 1 up top and 1 in the rear. So that controller would allow you to control all of them if needed.
wow that is exactly what I need! Will be ordering a few fans and this tonight
thanks!
