Full Version: XP Install changes system resolution on exit
Hi
I'm an XBMC and HTPC noob.
I've got a Pentium D 3.0ghz pc with an MSI R5450 pci xpress graphic card as the basis for my build, just working on getting the video right before messing about with the sound.
it all works great, using the hdmi port to feed my panasonic telly at 1920x1080
the problem is, every time I exit XBMC the windows resolution defaults to something like 640x480 and I then have to go into desktop properties to change the res back to 1920x1080
I have read a few threads that suggest this is a problem introduced with version 11
Is the solution to basically run version 10 instead or is there something else I can do? I would rather be using the newer version if at all possible.
thanks in advance.
Darren
ignore the above question, it does it when you reboot the pc too, with xbmc uninstalled. looks like my gfx card is going to be a pain in the arse then.
