2012-07-07, 01:43
Hi there,
I have recently installed XBMCfreak's frodo beta based on Ubuntu 12.04.
http://forum.xbmc.org/showthread.php?tid=134252
All is working pretty much perfectly, proper FLAC support from new AudioEngine etc, but my only problem is that FLAC 5.1 audio will only be output as a 5.1 PCM stream if I set "output stereo to all speakers" in the system->audio setup in XBMC.
Otherwise it will just output a 2 channel stereo stream.
Obviously this has the result of causing 2 channel stereo to be output to all speakers for stereo sources this is highly undesirable for watching TV episodes and music unless in party environment and even then I would prefer to use my high end receiver to make that kind of effect it needed.
Any ideas?
Thanks in advance
Any ideas?
Thanks in advance
