Full Version: 3 panel Movie widget - Center (Addon) section not working?
I love the new 3 panel widget, except on mine the left/right panels work perfectly and the center (addon) panel shows the fallback image and scrolls Addon1, 2, etc... I have addons like YouTube, BBC, and several more but they are not showing up?
any ideas for a fix?
I'm using 6/18 nightly build and everything else works perfectly!
focus the middle section and click on it, you can populate it then.
I just figured they auto populated like the other two panels Smile
thx for the quick reply... I really do like the way they work!
(2012-07-07, 02:41)Livin Wrote: [ -> ]I just figured they auto populated like the other two panels Smile
me not Wink navigation concerning mixed widget is still far from perfect, just allowing scrolling to one side.
i think i have some ideas to improve it.
