this is an add-on for RedBullTV Shows and live events.
Many videos are available in FullHD, but you can also change the maximum bitrate through the add-on settings.
When watching live events you have to push play to start the streams.
It's available via the xbmc.org eden repo.
Any feedback is welcome...
Have fun!
asde
Hi. Thanks again!
I have copy the link to the XBMC4XBOX Forum and add a Download link for scriptmodule.pyamf
test it a little bit later .
Regards Jan
Danke danke genau das hab ich gesucht!
greetz
(2012-07-07, 15:01)Martijn Wrote: [ -> ]I get this:
http://img4.imageshack.us/img4/2733/screenshot103d.png
It does play though (using latest XBMC build from master)
Edit: only this playlist.
The others show fine
Thanks, I fixed this.
(2012-07-07, 15:01)Martijn Wrote: [ -> ]It also throws an error when you have accidentally enabled internet proxy
Is there something I have to do for enabling proxies?
(2012-07-07, 15:44)AddonScriptorDE Wrote: [ -> ] (2012-07-07, 15:01)Martijn Wrote: [ -> ]It also throws an error when you have accidentally enabled internet proxy
You can enable "use proxy" in XBMC settings.
Not sure if that is something you need to catch in the plugin. Try for yourself and see what error comes up.
(2012-07-07, 15:53)Martijn Wrote: [ -> ] (2012-07-07, 15:44)AddonScriptorDE Wrote: [ -> ] (2012-07-07, 15:01)Martijn Wrote: [ -> ]It also throws an error when you have accidentally enabled internet proxy
Shure
I meant what I have to do in my addon so it works when someone uses a proxy... I thought it would just work.
(2012-07-07, 15:53)Martijn Wrote: [ -> ]Try for yourself and see what error comes up.
A log would be nice, but I will look for a free working proxy to test this...
EDIT:
I tested it with 2 proxies and everything is working fine...
Perhaps your proxy was blocked or the connection timed out.
(2012-07-07, 16:20)AddonScriptorDE Wrote: [ -> ] (2012-07-07, 15:53)Martijn Wrote: [ -> ] (2012-07-07, 15:44)AddonScriptorDE Wrote: [ -> ]Is there something I have to do for enabling proxies?
Shure
I meant what I have to to in my addon so it works when someone uses a proxy... I thought it would just work.
EDIT:
I didn't fill in my proxy. I just enabled it
So you get some funky error. Connection refused....
Can't make a log now cause i'm rescanning my library and that will take some time. Not something you should put in to much time for.
(2012-07-07, 16:46)Martijn Wrote: [ -> ]I didn't fill in my proxy. I just enabled it
Ahhh, sneaky
Then it makes sense to give you this "funky" error...
Update: v1.0.3
- Added live / onDemand events
Haven't got a chance yet to see if live events work on 1.0.3, but the on-demand ones work great.
Thanks for this amazing plugin
I waited until this morning for a live event to be airing. It was labeled as "LIVE NOW" on the list, and seemed to play perfectly. So that's pretty cool...
(2012-07-14, 17:55)cptmarginal Wrote: [ -> ]I waited until this morning for a live event to be airing. It was labeled as "LIVE NOW" on the list, and seemed to play perfectly. So that's pretty cool...
Yeah, nice
Im also watching crankworx live right now - seems to be working fine...
Sorry for the dumb question but this add on isn't showing up in the default xbmc.org repo. Do I need to refresh the repo some how or what? I am running Eden on an iPad.
