I'm setting up a screen with "Now Playing", where the artwork is displayed. I'm currently stock on making the artwork match my background, which has rounded corners. Is it possible to specify which corner of the artwork you want to bend?
Thanks in advance
Thank you! You're the man!
My apologies for bumping an old thread. This one comes up as top result on google search for "Kodi rounded corners".
I was able to create a diffuse filter - PNG file that has a white rectangle with rounded corners and the edges are Alpha channel.
However, I have no idea where to save this file so I can reference it with "diffuse". I tried the complete URL to my local server to serve this file as diffuse filter but that didn't work.
Can you please elaborate on where to save this diffuse filter and how to reference it ? I'm running LibreElec 8.2 (Kodi 17.6) on an Odroid C2.
Thank you for your prompt response @
Hitcher.
My bad, I should have elaborated on what I am doing, i.e. I'm working on creating a python add-on along with a Custom XML to create a GUI.
I was able to do the rounded corners by saving the PNG I created under <pathTo.kodi/.kodi/addons/skin.confluence/media/diffusefilter.png
and then in the XML I'm referencing it like this:
<control type="image">
<top>0</top>
<left>2</left>
<width>186</width>
<height>190</height>
<info>ListItem.Icon</info>
<texture diffuse="diffuseRoundedCorners.png"></texture>
</control>
This worked and now I have rounded corners, but I want them to look a lot more polished. Like they do in this mod:
https://forum.kodi.tv/showthread.php?tid...pid2758347
Any advice on how to get this glossy look ?
Thanks in advance.
Use another image control with a transparent texture and place it after the original control so it gives the effect you want.
Thanks. I'll spend some time on this and update in a day or two.
