Full Version: Android Remote
Hi everybody,
i´m struggeling a few problems with my android remote controls. (official, music pump, etc)
My aim is to control the xbmc completely without turning on my TV. I like listening to webradios using the rdio plugin. When i try to controll that app with the official XBMC Android remote i can acess the rdio app (Music - Music Add-Ons). I can see all the genres and stuff, can access to a specific folder but i cant see and acess the radio stations. When I try to select one a popup open and i can chosse "play folder". However it just doesn´t start to play.
I tried it also on an Ipad with the XBMC Commander and it worked perfectly.
Do you guys have any advice for me how I can solve that issue on my Android device?
Thanks a lot!
