2012-07-10, 00:20
I've been using Eden since the first Beta (now I'm on release version) and sometime around Beta 2 I've noticed a strange fps-related problem. It is not permanent and I wasn't able to track down what causes it, but it goes like this:
When I'm watching non-24p (namely 25p and 30p) content I'm noticing a little jerkiness sometimes - the video isn't smooth as always. So I bring on CodecInfo menu and it shows fps parameter (shown red on attached picture) all wrong - i.e. it may show 31.25 fps on 25p video or something like that. Everything else is behaving normally, it's just the fps number is wrong and the video is somewhat choppy (just a little, but I find that distracting). The CPU usage is also normal. No hard drive activity and the network speed is fine (I'm playing files from the NAS over 1GB connection, plus these are fairly low-bitrate AVI/MP4/MKV files).
The funny thing is that when I play 24p video in that situation - the playback is smooth as always even when fps numbers are still wrong! Only 25p and 30p videos are affected.
Restarting XBMC (not the Windows itself) solves this problem and the same video shows correct 25/30 fps number and run silky smooth. But the problem returns later.
I've got refresh rate matching and video sync enabled . The XBMC changes refresh rates correctly, according to file properties, as shown by my TV's info menu. I've tried all the video sync options (and even disabled it) and it not seems to be connected to the issue (the missed frames/error counter behaves normal all the time, showing a little sync corrections if any).
Again, XBMC switches to correct rate, (50Hz for 25p video, 60 for 30p), but _sometimes_ there's that strange slight choppiness. Which can be removed by simply restarting XBMC, with no settings changes whatsoever.
So, any idea what causes it? Please tell me what log/info I should post for you guys to look at. As I'm writing this my XBMC behaves normally (that son of bitch!), but I know the problem will return
Here's my setup - Zotac ION box with Atom 1,6 GHz, 2GBs of RAM, 32 GB SSD, running Windows 7 Home Premium and connected directly to Panasonic P50ST20 plasma via HDMI. I got the latest nVidia drivers and the latest stable XBMC release installed. By the way, what is the best driver's version for ION/XBMC combo? Maybe there's something going on here?
Thanks in advance for all the help!
Sorry for my English (not a native speaker)
P.S. [EDIT] Changed picture to the one from later post to show wrong fps and changed the name of the thread
